964 Forum 1989-1994
Random 964 Picture Thread
Old 01-29-2015, 04:56 PM
  #5506
Vandit
Vandit's Avatar
Thanks for reposting that instag vid. I would have never seen it since my usage of instag is primarily browsing young ladies w/ daddy issues and/or generally free spirited behavior. The car sounds good sparky.
Old 01-29-2015, 05:06 PM
  #5507
davidwilson11
davidwilson11's Avatar
Frank, what's the steering brace modification. Curious?
I'm off to search and find the popcorn.
Old 01-29-2015, 05:08 PM
  #5508
davidwilson11
http://www.ebay.co.uk/itm/Genuine-Po...-/321544351616 is this the one? So what's pro's to this, is it a must for 18" wheels?
Again im away to have a browse.
Old 01-29-2015, 05:29 PM
  #5509
Talat
Talat's Avatar
964 3.8RS fronts are 9J and they run 235 tyres from the factory, so obviously Porsche had no issue with it
Old 01-29-2015, 05:41 PM
  #5510
BLACK-BETTY
BLACK-BETTY's Avatar
Yeah, it sounds very nice. I'd hazard a G-Pipe and perhaps a cup pipe.
They came with 235/40 (& we're talking race car here)...
Here are pics. For a C4 it requires the line to be slightly bent. Easy peasy.
Here is the tech bulletin from Porsche. It's not essential many run on track without issue to date. But I would recommend it for piece of mind. Small price to pay. Yup that is the one.
Old 01-29-2015, 05:58 PM
  #5511
davidwilson11
Now that's interesting! Tell me what is the aspect ratio? 40 is what I would presume... This chap is running a 35.
Cheers dude. That's added to the list that's as long as my arm.
Old 01-29-2015, 06:05 PM
  #5512
Vegas993
Vegas993's Avatar
A 265/35 on the rear, which I've seen Francis mention several times, is 1.23% larger than stock. Not to mention, mismatched aspect ratios are much worse for an AWD car.
I run 245/35's which are only .43" smaller than the stock 16's.
Old 01-29-2015, 06:16 PM
  #5513
BLACK-BETTY
Originally Posted by Vegas993
A 265/35 on the rear, which I've seen Frank mention several times, is 1.76% larger than stock. Not to mention, mismatched aspect ratios are much worse for an AWD car.
Frankie you're not taking into consideration the side wall isn't straight with a stretch. You're comparing square fitting tyres with square fitting tyres.
Old 01-29-2015, 06:38 PM
  #5514
sparkyvw
sparkyvw's Avatar
It was WAY too loud. It was straight pipped. Exhaust from the previous owner was a mess and needed a quick fix. Now has full stainless steel exhaust on it.
Well interesting.
Right black whatever
You are in luck as conti doesnt make a 235/35/18 no more so im sure you will argue over this. But every other manufacture out there that does which isnt many. The widest recommended width for a wheel on a 235/35/18 is 9.5. Also the 235/35/19 version of the same tire which conti still make the recommended wheel width range is 8-9.5. So you should go ahead and call them and tell them they are all wrong. You must have some degree in tires with how you go on.
If you are that worried about rolling radius wearing out parts that you have to keep going on and on and on about it. I would suggest that you take your wheels off and put the oem porsche wheels and tires on. Seen as you seem to be so worried about it. You must be really fun to hang out with with how you go on about pointless things.
Old 01-29-2015, 06:40 PM
  #5515
sparkyvw
sparkyvw's Avatar
Right so you are saying that my 235/35 on a 9 is stretch. So to you the diameter is smaller becuase of the stretch. So that means it would be closer to oem spec. As a 235/35 is taller than a oem spec wheel and tire combo.
Old 01-29-2015, 07:03 PM
  #5516
Vegas993
Vegas993's Avatar
Frank, there is no stretch involved in this equation. I'm comparing a size you continually recommend as the official spokesman for 964 wheel and tire fitment.
A 265/35 on a 18x10 wheel is 1.76% larger than a 225/50 on a 16x8.
So you better quit running 265's, you might break something and your speedometer is reading slow, lol.
Old 01-29-2015, 07:17 PM
  #5517
BLACK-BETTY
A 265/35 on a 18x10 wheel is 1.76" larger than a 225/50 on a 16x8.
Frankie,
Between a 225/50/16 and a 265/35/18 there is a 1.75% change, agreed. This is within spec... because the tyres are square. The 225 is on an 8J and the 265 is on a 10J = square tire.
Putting a 235/35 on a 9J the tyre is no longer square so the percentage change no longer applies! The side wall is no longer vertical. It's now stretched. Your aspect ratio has gone out the window. I mean look at the pictures the sidewall is reduced hugely so clearly the rolling radius must also be reduced.
Which is fine it's your car.
I can't explain this more clearly.
Old 01-29-2015, 07:40 PM
  #5518
Vegas993
Vegas993's Avatar
I can't either, Frank. You're doing the exact same thing that you're telling Sparky he shouldn't do.
You're causing stress to the the transmission, throwing out ratios, stress on wheel carriers, throwing out speedo readings. Like I said, your car. But don't tell us that you aren't wearing a significant stretch, you are.
Old 01-29-2015, 08:12 PM
  #5519
BLACK-BETTY
Ok this is the best way I can describe it.
What ever you do your overall rolling diameter (X) shouldn't change. Your aspect ratio/ profile should be vertical. When it no longer is the figures goes out the window.
Your basing your percentage change on an aspect ratio/ profile this is vertical on a stretched tyre it no longer is. Above is much more than a single percent change
Old 01-29-2015, 08:27 PM
  #5520
Vegas993
Vegas993's Avatar
Can you read?
I'm not talking about stretched tires, I'm talking about a 265/35 on a 10 compared to a stock 225/50 on an 8.
The recommended tire size for +2 sizing is 225/40 and 255/35.
The 265/35 increases your overall rolling diameter +.44" or 1.76% over stock.
Quick Reply: Random 964 Picture Thread
