Not quite Friday---
Not quite Friday---
But I'm out of town the rest of the weekend, and I'm not connected where I'm going soooooooo
I learned that group riding can cause you to get a stone into your side markers, costing a few bucks to replace.
I learned that even though point 1 is a pita, I still love group rides!!!
My top DID NOT leak yesterday when I drove it in the rain, maybe temporary reprieve?
I'm going to run for the board on the local PCA- wish me luck with my continued infatuation with Porsche.
what about you- but I'll find out Monday afternoon when I get home.
christer- can you start the Monday post
Super Duper Moderator
I learned that ISO plugs can be hard to find so I had to order some from a UK retailer on eBay so I can complete my new head-unit installation.
Marc
Marc
I've learned that just about every time I check the air pressure in my tires they're low. All 4. I have to fill them up about every 3 weeks. Anyone else have to do this?
c
c
I learned that a fuel line can back off of the fuel pump after 15 years, resulting in your car smelling like a lawnmower.
But... tightening it back up, has been the cheapest fix I've had to do on the car so far.
Burgled
I am happy because it was beautiful top down driving weather in to work today and I get to go home in 15 minutes for the start of the weekend
I've learned that there are mods one can do that do not include the inherent Porsche tax. I wanted to add a K&N cone filter and open the air flow for sound reasons. I don't expect any HP gains from this mod but I do like the sound of huge amounts of air running through.
I went to the local autoparts store and bought a K&N cone. My intentions were to lay-up some carbon fabric this weekend into a snout and mill an aluminum blank to bolt up to the air meter. While at the autoparts store I spyed a pre-made plastic 3" inlet that had what looked to be a properly sized flange that was pre-drilled. I bought that for $5.54 and brought it home.
I pull the airbox to clean both the ISV and meter box. I took the inlet and using the gasket as a template drilled holes to correct the bolt pattern. This bolted right up to the meter box and I was able to fit the K&N directly to this. The filter clears the hood strut buy nearly 1/4". The airbox is only supported by the clamp for the intake so I need to bend some metal or build some carbon strips to mount support brackets. It worked well enough to test drive the car last night and I'll add the supports this weekend. The K&N is well up under the cowl and no where near the hood intake. The auto parts store also has pre-made intake pipes with 90 degree bends that could easily move the filter into an area more near the original airbox's snout position.
I'm thinking a heat shield below the cone may be nice and could lay-up a carbon plate and integrate the air meter supports with the plate and bolt these to the two original air box mounting bolts???
Anyhow, I've got $54 dollars into this intake. I'll spend another $35 or so for some fabric and the pre-made pipe for the intake. All in all, under $100 for something that I could easily spend $200 from a catalogs.
Alignment done, No bumpsteer or tramlining!! Drives like its on rails, never did that before. Took my mate four hours, and had to reset just about everthing. He cameout muttering about "lowered, spaced wheels, can't something be left standard".
He just invested in the latest 4 wheel alignment gear, its someting else ! flashing pods raising and lowering themselves on coloumns at the slightest tweak on the suspension.
I learned this week that you should look at the parts you have before you go shopping for new ones...ie: I have three electric window buttons....I really should have remembered to look for them before I spent $45 for another one....
Oh yea...once I fixed the window, I busted a part in my sun-roof. I know I don't have that part.
But the good new is that it is going to be 75 degrees and sunny all weekend up in the mountains, Aspens are at their peak of color, and roads are really twisty all over...kinda like heaven.
Location: The depths of Sherwood Forest, UK or if you're really unlucky, sat in your mirrors
I learned that after spending the best part of 6 months trying to track down an intermittent ABS fault, having an earth ( ground ) terminal fall off in your hand when checking all of them for the second time is a great feeling.
Cost price of repair £0.10 - personal price of not having wife complaining that the ABS light & buzzer came on again - Priceless!
