Refilling the manual transmission oil...any tricks for a clean job?
I drained off my tranny oil last evening and I'm going to refill it. Are there any special tricks for doing a clean job with that? It doesn't look like it'll be particularly easy to refill that sucker with the refill on the side and going at it from underneath.
Also, how much fluid does it take? It looks like the servie manual says 3.1 Liters. Is that right?
I used an inexpensive pump bottle. There is recent post on this subject, and several links to vendors were posted. I got mine at Pep Boys, and it did fine. Get one with a hook that holds the tube in the fill hole. That lessens the risk of the tube jetting back when you give it a strong shot.
You will, of course, get overflow once the tranny is full. That is how you know when to stop. Keep the drain pan in place!
Good luck
Good luck
Good luck
Good luck
Hello RedRS,
The following DIY is for a 993. Given the close genetics, I think it will help you.
http://p-car.com/diy/transmissionfluid/
Originally Posted by Monique
Hello RedRS,
It is a G50 like yours. The clear tube looks like a great idea to me.. I will use it next winter for certain.
If ever on this side of the white cliffs of Dover, come on by... I'll show you another Red RS
Originally Posted by Indycam
Warm oil flows much better than cold oil . Real warm oil flows much better .
I also bought a cheap hand pump at Kragen (same as Pep Boys or other generic auto stores). It really wasn't very hard, although I was amazed at how much actually went in! Obviously the oil will need to be supported at a higher level than the car (doh), I did this by wedging the bottle in a box with some rags on a stool (very technical in my garage!) Make sure you have ordered new washers rather than taking a chance with the old ones.
Jarhead
Yes! Be double sure you have the crush washers before you do the job, otherwise you'll notice a tiny leak down the road, have to drain the tranny, collect the oil, re-fit the new crush washer, and refill the tranny. Just trust me and use the new washer. And actually, the great thing about using the pump is that the oil can be pumped from lower than the transmission. Right below the transmission, in fact. Sure it takes a bit more elbow grease, but I think it's easier than running a piece of tubing all the way from the pump to the fill hole. Your choice!
Brian
Brian
Brian
Brian
Jarhead
It also makes it easier because you can tell right away when the tranny is full because a bit of oil begins to trickle back down your tube. That way, you know it's full before you make a huge mess. If you aren't right under the hole, it's harder to tell when it's full. Although the obvious downside is you have to get, and lay, under the car the whole time pumping the bottle. Enjoy!
Brian
Brian
Brian
Brian
