Pending projects and a few q?
#376
Professor of Pending Projects
Will you be opening up that gearbox just received? If yes, please share a pic of PTU after separated as planetary gear should be visible. You could also be the first on RL to document a PTU clutch pack dissection or I just can't find in search engine.
#380
Now, open the one I am taking out of the car...well yeah!! I want to look inside the rabbit hole...curious as to what went wrong with mine...
#382
Subscribed! You got so many projects, I was confused. Please setup about six cameras and create an IMAX production of the old box teardown I am curious about that PTU center diff breakdown too.. Peeps got me paranoid about the P-Gear
#383
Hi Jamie, because of a little I have with the crank sensor connector and you're about to replace yours, did you get part number 996-606-105-00-M14 which is an oval connector?
Or were you able to source a rectangular connector? PN 911 606 217 02
The oval connector will require upgrading the older female connector in the car to oval to accept it.
Thanks and keep the projects going. You don't know how helpful yours and others posts around here have been helping me!
#384
(3) Electrical Connector for Plug Housing Part #: 999-652-871-22-M100
(3) Grommet for Plug Housing Part #: 999-704-161-40-M100
(1) Plug Housing for Reference Sensor Part #: 999-652-916-40-M14
I am still working on the SC->RS project... waiting on some parts to be able to finish the rear suspension so that I can install the wheels back and roll it out to work on the 964...
