Manual steering rack (RS?)
Skippy
Came across manual steering rack on Ebay. Must be an RS part (964.347.011.02). Perhaps interesting for somebody.Manaual rack
Kris,
Thank you for the link.. didn't know this one.
FWIW, the 993 RS has the steerng rack as per the 964 RS.
Two types of racks were made for 964 RS: powered and unpowered.
The 993 RS used the powered one as did the 993 GT2.
Goede weekend
Goede weekend
Technical Guru
Monique,
Have you tried driving around in a 964 or 993 with a manual rack? If you haven't you should give it a try before you buy another power rack, IMHO it definitely changes the road feeling and for the better. Its makes the car feel more tossable(?) like the early 911s. Everytime I've driven a C2 with a power steering it feels like a school bus compared to my RSA. The other benefit is/was its around half the cost.
Originally Posted by martinreinhardt
Does anyone know how much weight I could save by replacing the power steering system with the 964 RS one?
I have one in my Speedster and it is a very nice up/downgrade .
The Euro RS always has the manual Rack , the 993 RS has a modified 964
Power Rack .
A good used PS Rack should be about 500 Euros .
Harald
Technical Specialist
Lifetime Member
Lifetime Member
Power Rack .
Power Rack .
Lead Rennlist
Technical Advisor
Lifetime Member
Lead Rennlist
Technical Advisor
Lifetime Member
Dear Bill,
The 993RS uses 18.5:1. The standard 993 uses 16.48:1
However after digging through the paperwork (when I should be working on my book) I have found that the standard 964 uses an 18.48:1 steering ratio.
You are correct in that the PET 6 parts catalogue shows the same part numbers for the 964 model year 1991 and up 964 347 009 04 is also used on the 993 Carrera RS.
Not quite so simple when we compare RHD.
This has been helpful because I can update my 993 Carrera RS data now with another subtle difference between LHD and RHD because they have different ratios.
Ciao,
Adrian.
PS: When you compare PET 5 to PET 6 a huge slice of data has been removed from PET 6.
Ciao,
Adrian.
Originally Posted by JasonAndreas
Monique,
Now you have me seriously thinking... although my steering ratio is the same as 964 RS. I wonder how much more tossable it would really be...
