964 Forum 1989-1994
Speedo problem
Old Mar 13, 2005 | 05:15 PM
deekay911's Avatar
deekay911
Default Speedo problem
Hi,
'90 tiptronic, and the speedo is starting to get erratic. Sometimes the needle jumps around, stops altogether, then starts again and is fine for a while. Whe it stops working, so does the OBC speed readout and the rear spoiler activation. Could it be the speed sensor, or maybe the speedo itself?
cheers
Deekay
Old Mar 13, 2005 | 05:52 PM
John Boggiano's Avatar
John Boggiano
Lifetime Member
Might be as simple as the connector on the back of the speedo head.
If you carefully pull out the speedo and break/remake the connection on the back, it might help.
Old Mar 13, 2005 | 06:16 PM
Adrian's Avatar
Adrian
Lead Rennlist
Technical Advisor
Lifetime Member
90% guaranteed to be the speedo.
If you hit 115kph (72mph) as measured by your right wheel sensor the rear spoiler will open. Only available on 89 C4s and 90 C2s and C4s.
Ciao,
Adrian.
Old Mar 14, 2005 | 05:29 AM
deekay911's Avatar
deekay911
Hi Adrian,
thanks for that. Can you explain what you mean by hit 72 mph? Thought it triggered at 50mph?
thanks
deekay
