Euro RS Hood Support
Technical Guru
I finally got fed up with my front hood shocks failing every other time my head was directly below the sharp & pointy locking hook in the front trunk so I ordered ($17) the hood support pin & bracket from the european Carrera RS.
Does anyone have a photo of the proper mounting location under the front hood for this bracket (far right in the above photo) and for the clip that attaches with the two tapping screws, where the aluminum support snaps into place when the trunk is closed (top center in the above photo)?
Happy New Year!!!
Happy New Year!!!
Jason,
Is this a genuine Porsche part? If so, can I trouble you for the source? My shocks are spent as well....when its cold out, its a real joy to go to the supermarket and use my forehead as a prop rod while loading groceries into the trunk!
And $17?????? I didn't know there were any parts for our cars that could be purchased for $17!!!! Are you sure you did not forget a couple zeros?????
BGL
BGL
You will also need a part number 999.085.001.02 socket head nut which will replace the normal nut mounting the front suspension mount at the position shown.
I will try to take a photo later today and give you a measurement of where to locate the upper part of the rod to the hood.
One thing to keep in mind is that the rod is designed to support a substantially lighter aluminum hood so you may not want to remove both your dead hood shocks.
Technical Guru
Originally Posted by BGLeduc
Jason,
999-507-372-07 retainer (1) $0.48USD
964-511-569-00 hood support (1) $11.88USD
964-511-551-00 rod support (1) $5.20USD
standard items;
N-011-524-7 washer 6.4 (2)
900-138-001-02 tapping screw (2)
N-022-148-1 locking nut M6 (1)
and the part I didn't know about and now need to order, thanks CupCar!
999.085.001.02 socket head nut (1)
I just looked in the Technical Workshop manuals and it shows four (4) additional rivets that attach the support bracket to the hood, of course they aren't listed in PET. They are aluminum 3.2mm x 5.8mm. I'll look for part numbers sometime other than today, I have to leave now. Happy New Year!!!
I will try to take a photo later today and give you a measurement of where to locate the upper part of the rod to the hood.One thing to keep in mind is that the rod is designed to support a substantially lighter aluminum hood so you may not want to remove both your dead hood shocks.
Originally Posted by 964RS
And, ...the photos.
Here is measurement that may work for you. The distance from the edge of hole closest to bracket and edge of bracket is 90 mm. I am hopeful the steel hood has the same hole to measure from.
One thing worries me: the steel hood is *very* heavy, to the point of being a pain to lift without the shocks. I would not trust this flimsy rod to hold it open alone.
Are you keeping the worn shocks on to help the rod, or removing them? Or do you have an aluminum hood already?
The RS bonnet is aluminium (aluminum) so it is much lighter. I don't think I'd be happy to have support only on one side. Has anyone with standard hood done this yet? I'd be interested to know how robust this support is.
Harry
Also, helpful morons try to close the hood without noting it is not supported in the usual fashion and thus bend the rod for you- would be a real issue with a heavier hood and an overstressed rod.
Super Moderator
Needs More Cowbell
Needs More Cowbell
I would be leaning towards using 2 prop rods with a steel hood.
(I'm too embarassed to post pictures, as the insides of my Cup hood are not nearly as clean as 964RS and Cupcar )
Technical Guru
For the time being I plan to keep the old non-working hood shocks in place. When spring comes and my garage isn't freezing cold I'll pull out the shocks and see what happens. If worse comes to worse I suppose I could always just buy an aluminum hood...
