964 body offset compared to chassis
I read somewhere that the aircooled 911 body shell was something like 3 cm off center from left to right compared to the actual chassis
Looking at my 964 I clearly notice that the wheels are more inwards on the right side compared to the left side and I would like to know if anyone can confirm that
Yes, the 964/993 are off-center, wheels are closer to the fender on the driver's side. I've heard it's to compensate for driver weight but have no idea if that's accurate.
Get out…. Really?? That’s info I need to have because I always thought it was strange that the clearance seemed different from side to side- especially the rear.
I heard this so long ago I can't remember the source but here's a couple...
#8 here: https://flatsixes.com/cars/porsche-9...r-porsche-993/
https://rennlist.com/forums/964-foru...-center-2.html
Quote from this thread:
go out and measure yours
In back the easiest and most obvious is on the inside between wheel and chassis but between wheel and lip also shows, every single one that I have measured, (about a dozen +/-) has ~ .25" less clearance on the inner right and ~.25" less on the outer left
seats/steering are another off kilter spot
Holy **** this just blew my mind. I was convinced that when I reinstalled my front subframes and suspension I had installed it off center due to the differences in front wheel to fender clearance... this is good news! Thanks RL.
