Door stay broken
Door stay broken
Hi,
the metal sheet inside the leftside door, that is connected to the doorstay, is broken of and causes a very annouying clicking noise.
It probably needs to be welded.
Has anyone had the same problem and what did it costs you to fix it?
Yep - type911 do a repair kit.
http://www.type-911.co.uk/gp_exteriors.htm
"911 Door Strap Repair Kit, repairs door strap area damage without welding, kit repairs one door (not A pillar) in minutes, complete with instructions" £54.00
Rob,
how will that work? Have you done this yourself also?
The metal strap is broken off at 1 side, I don't see how those 2 plates will fix that.
And I don't want to find out after spending 54 Pounds that this is not what I need ....
If the check strap is what is broken, the "door check" assembly is also available. Sorry don't have the part numbers, but that is a common service part that any dealer and most shops will have on hand. If you don't know for sure what is broken, perhaps you should perform some disassembly to find exactly what you need. Good news is the car can be driven with the door check out of service. Just remember to hold on when the door is open! Good luck.
Springer,
I know exactly what is broken and it's not the door stay itself, that is ok.
It's the metal sheet inside the door that holds it, has broken off at one side.
So it should either be welded or the suggestion from Rob should be able to do it.
Although I do not see how...
Hmmm - I'm not sure. I've not actually done the repair, but I have changed the door check straps (also from type911, although I bought mine from OPC)
Does this look like it will help? (£14 from type911)
Rob, if my memory on what i've seen is correct ;-p then the part that the above attaches too is the inner door skin, that's where i've seen the skin tear horizontally, it then flexes as the door opens/closes and makes a creaking sound. I'd bee inclined to drill a very small hole at the end of the tear/crack, then tig weld the tear itself. (after first removing the batt, etc for elec isolation)
kevin
kevin
Toon,
For some reason, this problem pops up quite often on the 993 board. There's some belief Porsche deleted the weld inside the cabin, which helps minimize movement of and support the stay (I've not personally checked any 993s, so I don't know if this is true). Anyway, this problem does seem to be more common on the 993. Looks like the search function isn't returning many of the (good) threads from the past, but it still might be worth a shot to perform a search on the 993 board. If that doesn't give you the information you want, you could make a new post.
Here's an old thread from the 993 board:
Door Stay Thread
And, one from this board:
Door Stay Thread_2
Good luck!
Door Stay Thread
Door Stay Thread_2
Good luck!
Yes, this is very common on the 993's. I had to do THIS procedure on my car to relieve the stress causing the click. I might have shaved just a tad too much from the rubber blocks that create the pressure against the stop points to where I now only have subtle stops in the door opening mechanisms, but still enough to hold the door at the various stops. It really does nothing to fix the stress fracture forming on the door jamb, but just puts less pressure on it. Either way - I am now click free when opening and closing the door and I intend to put a spot weld on the frame to stabilize the stress fracture later on.
Rob,
the picture you shown last is the door stay and that is fine on my car, but where the two bolts connect to the door itself is broken (the welds of the metal sheet inside the door).
Randall,
yeah I've searched the board and found the same 2 threads. But unfortunately the 933 one is about the connection to the A-pilar and that OK on my car.
And your original thread is missing the pictures so I'm not sure if we are talking about the same thing there ....
Randall,
Toon,
Yup, I think the 993 problems have been limited to the A-pillar, though I could be mistaken. And yes, too bad the pictures are missing from those threads. There are many other good threads on the subject that are just flat-out gone. I'll post my pic from the 964 thread tonight. But, it was only the weld that's visible in the door jamb, at the A-pillar (body of the car), not on/inside the door itself.
This is the first I can remember someone having the weld fail on the door itself....
