964 Forum 1989-1994
Future date/ Back date/ 964 Transformation
Old Feb 24, 2020 | 05:43 PM
  #106
GentlemanRacer's Avatar
GentlemanRacer
Originally Posted by cobalt
They do very nice work.
Looks like you are going with the window mounted mirrors?
They do.
I am going door mounted. I couldn't get comfortable with the placement of the window mounted ones. The style is in keeping with a 70's RS so the Durant style or a pre 69/or 356 b mirror. There are some differences, but we will see how they look once the car os finished. The drill holes are the same.
Old Feb 25, 2020 | 01:02 AM
  #107
Bigwood's Avatar
Bigwood
This is a epic build! I can’t wait to see how it ends up!!
Old Feb 25, 2020 | 05:16 PM
  #108
GentlemanRacer
Thank you.
Old Feb 26, 2020 | 08:02 PM
  #109
GentlemanRacer
Look what just showed up!
Custom FIKSE Fuchs.
Time to test the fit.
All fingers and toes crossed!
Old Feb 26, 2020 | 09:25 PM
  #110
misterbeverlyhills's Avatar
misterbeverlyhills
Vince, just curious, what size are they and can you share the price? I am on the fence for getting them on my car.
Old Feb 26, 2020 | 11:52 PM
  #111
GentlemanRacer
They are 17 X 8F/10R. I also considered 18 inch as well, since there are many more tire choices available, but the 17 allowed for a slightly higher profile rubber which I think gives it a good balance between modern and classic look. Once the car is lowered, it should look really good.
Check your pm
Old Feb 27, 2020 | 08:41 AM
  #112
cobalt's Avatar
cobalt
^^^ Good choice they are not too big and look very much like the originals unlike some I have seen.
Old Feb 27, 2020 | 01:07 PM
  #113
GentlemanRacer
^^^ They are extremely close to the original. I was very lucky to get these made. There is a usual 6-8 month waiting time to get this made, but because they are local in Vancouver they squeezed in this set in between their usual Singer and other quota.
Old Feb 27, 2020 | 01:15 PM
  #114
GentlemanRacer
My biggest concern was the fronts as I went with quite an aggressive fitment in terms of off set. It seems to fit perfect and once cambered and lowered I think it will be right on the money. There will have to be some adjustment or cutting of the liners to prevent rubbing, but that will be in a few weeks once the suspension change and calibration starts. The end is in sight!
Old Feb 27, 2020 | 01:39 PM
  #115
LPMM's Avatar
LPMM
Looking good Vince
Old Feb 27, 2020 | 03:34 PM
  #116
964.4L's Avatar
964.4L
Wheels look awesome!
Old Feb 27, 2020 | 03:38 PM
  #117
GentlemanRacer
Many thanks guys!
Old Feb 27, 2020 | 03:48 PM
  #118
spartansix's Avatar
spartansix
Fitment looks aggressive but nice - will they clear the fenders with a little more front camber? What are the offsets?
Old Feb 27, 2020 | 05:13 PM
  #119
GentlemanRacer
They should. It should all work together once the suspension parts go on. New dampers, tie rods, etc etc. Car will be lowered moderately so the camber will be adjusted for a good street ride. By my calculations this should bring the top part of the tire in line with the fender and should provide enough clearance for turning. Front ET 43, Rear ET 56, however this is not exactly how they will fit, because of the way the wheels are constructed. I made some adjustments so the inner barrel in the rear will clear the trialing arm. The reason for the aggressive front fitment is to push the track as wide as possible, to help with front end grip. Together with sway bars I am hoping to make the car neutral, and dial out the understeer to my liking.
Old Feb 28, 2020 | 09:52 AM
  #120
Greg Wolfe's Avatar
Greg Wolfe
I approve of all of this.
Mr. Wolfe
