Pulled the Seats Out..........
Finally got the call from the upholstery shop that my slot was open and to drop the seats off. I've never removed the seats before, but it was straightforward and easy. Man those seats, including their bases, are really heavy! I didn't weigh them but I'd guess 35 pounds or so?
Anyhoo....... question. Both seats have the exact same electronic adjustment functions, 8 way. However, I had two items to unplug on the drivers seat, one on the passenger. Why would that be?
I didn't realize the seats were made for Porsche by Recaro either. I'm probably the only person here who didn't know this.
Here are the two wires underneath the drivers seat:
Both seats had this one.
Only the drivers seat had this one.
small one is seatbelt light/warning.
Ah. That makes sense.
How long for the shop to refinish the seats, and what's the work you're having done? Considering this for myself, as the driver's side upholstery is in good condition, but the seat padding isn't giving much support anymore.
I got on his schedule last November with an expectation of the seats being done sometime in March*. We have touched base about every 1.5 weeks since mid March. Here is it the end of April and he's ready. He said I'll have the seats back by the middle of next week. So, 1.5 week turn around.
He's good, that's why he's always busy. Fella doesn't advertise. His shop is in the middle of nowhere. Been around a long time, I though he'd retired.
I'm having the inserts redone with cloth and all of the leather/vinyl recovered in leather.
*I'd though my car was going to be at a shop being painted last March but decided I like all of the rock chips for the time being. So I cancelled.
Timely thread; I'm pulling my seats soon to swap out for some sport seats and I've read of many others who have had difficulty with removing stripped bolts. Did you have any trouble with your seat bolts and do you think it is wise to replace them?
Can someone confirm how many and what kind of bolts are needed for the front pair of seats? I want to be prepared before I start on mine.
I pulled the drivers side over the winter to fix a failing power seat adjustment switch. I made the mistake of using an allen wrench instead of the T40 Torx bit. After it got rounded out I had to use an extractor bit and a ton of elbow grease. It's a crazy idea, but the right tool really does make the job go easier!
The seats take 2 torx bolts on the front of the rail and 1 in back, so a total of 6 per seat.
This is what i use. This thread just reminded me that i have e run out and need to restock.
You can buy at McMaster- or local hardware store. I replace them with harder bolts that the factory used- cuz the oem bolts are way too soft.
Fwiw- if you are tall, you can mount the seat on the farther back holes and gain a little room.
According to the seat article in 000 Magazine the stock 964 seats weigh about 50 pounds each.
I have the same box of bolts. A few of them
use a quality hex socket on these. Hold the wrench steady and untorque it.
Ive yet to strip one.
Attachment 1303153
Attachment 1303153
I have the allen head bolts like those shown above.
I'm all about torx bolts but chances are you'll need to approach the bolts at an angle (why soft bolts strip) unless you have a socket set with torx bits. Be sure to use an allen wrench with a ball end tip like this one. You can't get a tork bit that works at an angle, that I'm aware of.
