964 Forum 1989-1994
Intake madness. Teardown begins....
Old 06-02-2020 | 11:09 PM
  #466
RicardoD's Avatar
RicardoD
Honer pics for that smoooooth intake flow to match the throttle body only to be choked off at my pedestrian stock heads
Old 06-02-2020 | 11:41 PM
  #467
Goughary's Avatar
Goughary
Wow! That is impressive...super cool!
Now do a 9h ceramic on the inside so the gunk will have a hard time sticking...and you will be all set. But don't do that until you Cerakote the outside since you don't want to cause the Cerakote to not adhere...
Old 06-03-2020 | 06:04 AM
  #468
Peteinjp's Avatar
Peteinjp
Sweet- I was on the fence but now.....
Paint the exterior with something that insulates and you'll be solving the heat soak issue as well!
Did they give you the cfm measurements per runner?
Pete
Old 06-03-2020 | 12:22 PM
  #469
RicardoD's Avatar
RicardoD
Pete, I could send them off to Jet Hot for ceramic coating in their matte silver or chrome finish just like I did my headers. Yet more money. I will probably sand blast them and Cerakote this weekend.
I do not have cfm measurements.
Ricardo
Old 06-13-2020 | 03:53 PM
  #470
RicardoD's Avatar
RicardoD
Intake madness complete!
BEFORE
AFTER
The following 7 users liked this post by RicardoD:
911Jetta (06-25-2020), cobalt (06-14-2020), HiWind (10-20-2020), JasonAndreas (06-13-2020), JP-"S" (05-13-2022), Lukas (02-15-2023), willmip (06-14-2020) and 2 others liked this post. (Show less...)
Old 06-13-2020 | 07:19 PM
  #471
Goughary's Avatar
Goughary
That's amazing...great job Ricardo!
Old 06-13-2020 | 07:35 PM
  #472
Blu RS's Avatar
Blu RS
VERY nicely done! Have greatly enjoyed seeing this part of your project thru to fruition!
Old 06-13-2020 | 11:17 PM
  #473
Peteinjp's Avatar
Peteinjp
Looks great Ricardo! What did you end up painting the runners with?
Pete
Old 06-13-2020 | 11:47 PM
  #474
RicardoD's Avatar
RicardoD
Outside of runners in Cerakote glacier silver, brightest silver.
Old 06-25-2020 | 05:04 PM
  #475
titleistaddict87's Avatar
titleistaddict87
Well guys, dove into this madness as well... entire manifold is off the car and getting refreshed / cleaned / replaced. Can't wait. Question for the experts. I started peering around the intake valves and noticed this gap on the #5 intake valve (pic 1 & 2 closeup). All others look like pic #3. What is the gap I am looking at and if it's a problem is there anything I can do about it at this stage with the engine still in the car?
Old 06-25-2020 | 05:51 PM
  #476
RicardoD's Avatar
RicardoD
The valves open and close depending upon the cam position. Perhaps your car is in the state where #5 intake valve is opening?
Old 06-25-2020 | 06:08 PM
  #477
titleistaddict87
was thinking this as well. If I rotate the crank it should move?
Old 06-25-2020 | 06:38 PM
  #478
Goughary's Avatar
Goughary
Yes
Old 06-26-2020 | 08:56 AM
  #479
cobalt's Avatar
cobalt
Looks good just don't rotate it counterclockwise
Old 10-06-2020 | 10:41 AM
  #480
Peteinjp's Avatar
Peteinjp
Just catching up to you guys bit by bit. I ran into a problem with one of my throttle plate bolts and don't have time to source a new one as I have to get this in to the mechanic tomorrow. I used a m4 screw just like the one the Ricardo showed before that has the larger head. Here you can see the difference. It's hard to see but not only is the head larger the angle of the sink is slightly different with the original part being a hair more shallow.
I don't have a lathe but I do have a belt sander and I've spent countless hours shaping stuff on it. I threw the screw into the cordless drill and rotated it at full speed as I shaped it. Doing the conical side was not easy but it worked out fine in the end. Maybe not the most "correct" method but functionally its just fine. I'll use this one on the resonance flap.
Psyched to finally put my WOT doodad to use!
Extra special thanks to Ricardo for helping out with the bearings!!!! I noticed that the seals are on the opposite side on the replacements. If you put the seals to the inside as the are originally the squared off shoulder of the bearing that has the bearing info will be on the inside as well meaning that the bearing will have to be pulled to see it. I put them in that way.
Pete
Quick Reply: Intake madness. Teardown begins....
