964 Forum 1989-1994
Tail light seal question
Old Jun 11, 2018 | 06:56 PM
WAH's Avatar
WAH
Default Tail light seal question
My drivers side tail light is cracked. I found a good used one but it does not have the seal/gasket.
Question: Can I use the old seal from my cracked unit? It seems to be glued in places so I have
not tried to pry it off the frame. Thanks
Old Jun 11, 2018 | 08:10 PM
JohnK964's Avatar
JohnK964
There was a change on tail light seals not sure when that was. Older version looks like it completely surrounds the light updated ones just seal the ends
Old Jun 11, 2018 | 08:22 PM
WAH's Avatar
WAH
yes, my ‘91 completely surrounds the frame. Wondering if I can peel it off intact to use it on my replacement unit.
Old Jun 11, 2018 | 08:25 PM
JohnK964's Avatar
JohnK964
That’s odd my MY 91 built Nov 9 1990 has the different ones but I don’t see why you couldn’t reuse the one you have providing it doesn’t get destroyed in the process
Old Jun 11, 2018 | 08:41 PM
WAH's Avatar
WAH
what is your build date?
yeah I have just been reluctant to pry it loose.
JohnK964's Avatar
JohnK964
Just look the gasket like you have was used upto 1990 the other 91 on
Old Jun 11, 2018 | 08:44 PM
JohnK964's Avatar
JohnK964
Stated my MY91 was built 11/09/90
Old Jun 11, 2018 | 10:48 PM
WAH's Avatar
WAH
10 4 speed reading...... I will check mine tomorrow
Old Jun 11, 2018 | 10:52 PM
JohnK964's Avatar
JohnK964
It is entirely possible a P.O. put the older gaskets on your car and that might explain why they are glued on replace gaskets aren’t terribly exspensive. I see your a realitive new owner of a 964 Congratulations 👍
Old Jun 12, 2018 | 09:01 AM
cobalt's Avatar
cobalt
They replaced the surround seals on all the lenses in 1991 AFAIK. They were having problems with corrosion and moisture/dirt buildup with the old seals. . If you can't peal the old one off I have several of the old style both new and used.
Old Jun 12, 2018 | 11:51 AM
WAH's Avatar
WAH
i can use a new one that goes all the way around the housing
how do I connect with you on that?
