aircon lines removal
They disconnect innside the rear fender there is rubber boot on them where they pass thru the fender if I remember correctly it comes off from in side the engine bay there is a strap that also holds them in place behind and above the blower motor in engine bay so probably easier to remove from engine bay side
aircon lines
new rubber lines
thx ! I managed to get them out through the engine bay , I was surprised that after 29 years the coupling bolts came loose without
problem. The bolts holding the lines on the compressor were an other story...they were real tight and after using some oil and turning back
and forth they came loose with a lot of
protest noise.
the threads on the aluminum lines look like new !
New rubber lines will be fitted...
To be continued
