964 front fog light lens replacement?
Noticed my 964 has one fog light with a cracked glass lens... can these lenses be replaced easily? or does one have to break through a glued seal and risk cracking the old plastic housing?
I see there are replacement lenses being sold, which are obviously much cheaper than buying a whole unit.
Am sure these glass lenses are often broken with road debris...
I just was working on such a situation myself this morning. I also had one lens which was busted. In my case I took the front housing out, and took a razor blade across the sealing surface. The glass separated easily from the housing. Since that worked, I ordered up a pair of lenses off a seller on eBay. Hope install will be as simple. I'll need a good adhesive I think.
Here is my thread on fog lens replacement https://rennlist.com/forums/964-foru...ht-repair.html
We also discussed some of this over here ...
https://rennlist.com/forums/964-foru...placement.html
and another pointer for fog lighter adjusters,.. if they happen to break...
https://rennlist.com/forums/964-foru...int-redux.html
=Steve
=Steve
