Chronicling the restoration and rebuild of Wilbur, the Pig
#61
Leaving the car parked outside for a week was fortuitous. A week of periodic rain and snow revealed about 8 oz. of water on the floor of the car. I traced the water back to the right side rear quarter window. Looking under the window seal, I also detected some rust on the outside of the window frame. Glad I caught this leak, and the rust on the exterior window trim.
So off come the two rear side windows. I was expecting a project with plastic removal tools and such, but the windows popped right out with my bare hands. I hope they go back in as easily. I broke out the Dermel and carefully grinded the rust off the window frame. Thankfully it was just surface rust, no real damage.
I’m wondering if some dum dum will stop the leak, or if a new window seal is needed? I will give the dum dum a try, but any advise here is welcome.
The interior has been stripped to bare metal. The goal is to remove any remaining paInt and rubber this weekend, and begin prepping the car for paint. I was quoted $4.000 to have the interior painted. I’m planning on just using a rattle can, and will save that money for the new suspension.
Maybe it was the beer, but I was iinspired by the Rennline airbag delete cover to drill a few holes in the door trim. The weight savings was negligible, but the car looks faster. Purists look away.
Discovered water leaking through side rear window
Pushed the window out easily
Windows out
Knocked down rust on window trim
Inspired by Rennline airbag delete panel
To match the look here
Purists, look away.
#62
I'm starting to get impatient haha so keen to see it painted! You could probably pick up a cheap compressor, spray gun etc for a few hundred dollars.
#63
Paint booth will be the next project.
#64
I’m with you on the impatience, Dingo. Thanks for the good advice on a spray gun. This is a big project. But my mechanic highly recommended a catalytic paint that comes in a spray can. We color matched the paint. I even bought a few extra cans for the roll bar we will be fabricating.
#65
Still sorting out the seats. The Tillets are perfect if you need additional headroom. I purchased a Fenn Lane sunroof delete panel, however, so headroom won’t be an issue. The Recaro Profi XL’s maybe, but they’re a bigger than I’d like. I’d like to try Sparco. Hoping I can try a few seats at the track and get that sorted out.
#66
So I haven’t been flamed by anyone for the holes in the door as yet. This Forum seems a bit more laid back than the 993 Forum where I’m sure someone would have torched me.
Final push is on to finish the sanding and preparatory work. I’ve taken all the lines apart so I can access all the recesses. I honestly hope I can remember how to put it all back together. I tucked the harness that leads into the roof inside the recess by the rear side window. I’m planning on deleting the sunroof and the lights, so I’m guessing it’s just a vestigial appendage to be tucked away.
I had a racer back in high school that I decided to “add lightness” to. I took that whole bike part into pieces, and could never quite figure out how to put it all back together. I’m hoping I have better luck with Wilbur.
Almost ready, but still some nits
Getting into the recesses
Last time this harness will be seen
#67
Getting into the recesses behind the wires is a chore
Not sure anyone will ever see the paint job back here, but it’s betting done properly
#70
Uploading photos is not going smoothly, sorry. Still not quite ready for painting the interior, but I did paint the former rusty side rear window where the rust had invaded. Nice to finally smell some fresh paint in the garage.
Before
After
Before
After
#74
Looking forward to this weekends updates jim
#75
Painting the girls’ bathroom, not the 964
Thanks for the interest Dingo!
Sadly little progress this week as Mrs. Foxman decided that the house needed a spring refresh. Instead of painting the 964, I painted the girl’s bathroom.
Track season starts this weekend with a PCA event at New Hampshire Motor Speedway. So the 964 won’t be getting much attention this weekend.
Hopefully next week I can begin paintkmg in earnest.
