Removing Original Head Studs
#31
![](https://cimg1.ibsrv.net/gimg/rennlist.com-vbulletin/1024x608/imag0176_9666538f210b989ada3a6b0b7e0807dcf17b5c69.jpg)
Btw: Im waiting for you to explain "almost an inch lower" voodoo of fluid dynamics here, because I don't get it. https://rennlist.com/forums/924-931-...-collar-2.html
#33
#34
Check my locale again...., that's "gris gris"....
T
#35
House of the rising sun maybe?
I'll give these for free if you promise to use them. Would be such a waste to not reuse them after all these were installed only once...
#36
I was not and am not a proponent of reusing removed factory studs.
I'm quite sure that's abundantly clear to anyone who read this thread except you....
T
#37
I'm perfectly aware of that but it's fun since you bite based on author, not content.
#39
Was pulling studs for my backup race engine (ironic since I'm not finished the 1st one yet...
) and I remembered this thread when I was almost finished removing.
So, I whipped out my tablet and propped it up to take a vid of the time it takes per stud using the TIG method.
Basically, you just make a few vertical passes with the torch about 2 inches in length, then weld the nut and remove.
I use the T bar so the force isn't one sided like a ratchet (same tools in pics above from a year+ ago).
I lost my ground when moving to the nut, and still total ET for 1 stud, less than 2 minutes.
T
T
beamishnz (10-24-2019)
#42
And you are right 100%.
My helper's (guy walking through frames) boots run a close second though...,
T
