Group Buy High Quality Billet 951 8V Adjustable Cam Gear
I use Electromotive on two of my cars so I'll have to check if it accepts a hall signal. I suppose that any solution would need to be good for any ECU out there and they all will accept a missing tooth afaik.
Location: Bangkok, Thailand, Milpitas, CA & Weeki Wachee, FL
1 Post
I have Electromotive TEC-GT as well, it will be made for compatibility with the TEC line for sure and yes Hall sensor is just fine. No, 968 and S2 did not use Cam Synch, but do have a 60-2 flywheel. I have a custom machined 60-2 trigger Billet 951 flywheel. That I will replace the Clewett setup with.
I could have sworn I saw some sort of sensor on the back of a 968 cam housing??
...oh and I'm in for this deal if you haven't counted me already.
1 Post
Originally Posted by V2Rocket
16v 944/968 have a hall-effect sensor on the back of the cam gear housing to pick up TDC, and re-set the "counter" of flywheel teeth.
1 Post
Originally Posted by Jon951
FWIW I'm also using the Electromotive TEC GT
1 Post
We are on the same path except I used an S2 flywheel and housing to replace my front mounted Clewett. Smaller clutch but I'm not running huge hp and I've had no issue with it. I looked at the custom 60-2 for the turbo, it's a nice piece.
That is great, sorry for the misinformation previously, my bad, never assume. Great to here you are in, only need two more, Yay!
I see you are from Palm Beach, there is a master tuner on Electromotive Tec-GT's there. I thought about shipping my car over there to them. I forgot the name of the shop, but you can see from the Electromotive Web Site. Uwe spoke highly of them and Dave Smith up in Panama City.
BTW, what is your name?
Magk944:
My name is Mike, I don't know why my signature isn't showing, it's set to show. Here it is anyway:
Mike & Gina
Rennlist Members #070719-6918 & #080718-9060
Our Fleet: 1985 308QV; 1986 951 (x2), 1986 944 (from new), 2000 996, 2002 ACS3, 2005 CL55 AMG, 2016 Tiguan
1 Post
Mike:
Yes, that is the one! Thanks for the information. I will fly back to Florida on Friday. What was the outcome of that cam sync in your pics? Did it work satisfactory? Do you have a picture of the sensor mount? The gear appears to be aluminum which is surprising. I will send you a PM, with my number we should chat when I get back on the East side.
