Ealokens Porshe 951
Old 06-14-2017, 06:17 PM
  #181
ealoken
ealoken's Avatar
So, the plan is about this.
LA sleeves
Wossner pistons
H-conrods
New turbo
Oil channel fix in the engine block
New oilpump
New waterpump
New And bigger oilcooler
V-mount radiator/intercooler (bigger is better)
And all the tiny
Bolts, seals etc.
Budget, 6000 $
Old 06-14-2017, 06:53 PM
  #182
Voith
Voith's Avatar
Found the cause? What is the situation with other bearings? Is epoxy on intake ports still on there or was it sucked in on that cylinder?
Old 06-14-2017, 07:07 PM
  #183
odonnell
odonnell's Avatar
You said earlier the upper balance shaft had a bad bearing. Do you think maybe there's a connection there? Maybe it was allowing oil that was supposed to go to the #2 rod to just escape back to the pan?
Old 06-15-2017, 02:09 AM
  #184
ealoken
ealoken's Avatar
I did check that out Yesterday, And it Looks in great shape.
Old 06-19-2017, 07:34 PM
  #185
ealoken
ealoken's Avatar
All but one f&@@ bolt... machine shop next..
Old 06-19-2017, 10:03 PM
  #186
Humboldtgrin
Humboldtgrin's Avatar
Scrape the nasty oil funk out of the hole around that broken stud and let it set in penetrating oil for a couple day, take a hammer and tap on it ever hour you can for those two days. Then clean the blocks deck and place down gorilla tap or something of the same to protect the block and use a really nice pair of vise grips and work the stud back and forth for as long as it takes to start working it loose. After it starts to loosen up you can work it out slowly by using a loosening and tightening method.
Old 06-20-2017, 03:24 AM
  #187
ealoken
ealoken's Avatar
Im so leaving this to a machine shop.
Old 06-20-2017, 11:03 AM
  #188
951and944S
951and944S's Avatar
What do you mean by - "Oil channel fix in the engine block"....?
T
Old 06-20-2017, 11:05 AM
  #189
ealoken
ealoken's Avatar
T
In the channel from the oil-pump and over to the Cranc,rods etc, there is a minor change where the oil goes to sylinder two, my mechanic has a tweak for this.
Pictures will be posted.
Old 06-20-2017, 11:08 AM
  #190
951and944S
951and944S's Avatar
Very much looking forward to it....
T
Old 06-20-2017, 01:21 PM
  #191
Voith
Voith's Avatar
Why did it fail, what was the cause?
Old 06-20-2017, 01:38 PM
  #192
V2Rocket
Rainman
V2Rocket's Avatar
T
first thing that came to mind was a "turning vane" like youd see in HVAC...lol
Old 06-20-2017, 02:04 PM
  #193
ealoken
ealoken's Avatar
Rodbearing on 2 syl.
i think if i had used the car more last year, it would have failed.
Old 06-26-2017, 01:19 PM
  #194
ealoken
ealoken's Avatar
So small uppdate, getting a bunch of parts cleaned and coocked this week, and getting the last stud out.
Voith here sold me a nice cranc, Ian at 944online sold me all i need for my block in pump`s, bearings, seals etc.
H-profile rods are ordered, the engine block will get nikasil treatment and some new pistons.
I also got an 71 degree thermostat.
But the question, what turbo schould i choose? Holset HX super 35 ? Garret GT3576 sith Tial house?
Borgwarner S-200sx or EFR?
Im aiming at 450 whp and a good long powerband.
Old 06-28-2017, 01:23 AM
  #195
Noahs944
Noahs944's Avatar
I sense your spirits are high... a "good attitude" mate.
Sorry to read of the mechanical failure... big bucks to repair.
Looks like your are setting the bar high for power.
Quick Reply: Ealokens Porshe 951
