Broken AC Compressor Bolt
My AC/alternator belt started squealing recently, I tightened it up once, but went to do it again and I see the forward top AC mounting bolt was sheared. At least part of the threads are showing on the back side of it so I should be able to get it out.
This same thing happened on my 968.....WTF?
I guess put it on the to-do list, I did tighten the belt a little and the squealing is limited to about 20 seconds after start up. However, I won't run the AC until it's fixed.
My fix on the speed / reference sensors with new wiring to the DME is now considered a success, it used to die after the car got heat soaked and I would have to wiggle them around to get it going again.
The recent alignment and rebuild of the front A arms is also a success, just a few little items left to fully sort the car.
Rainman
Yea, I've seen a few of those bolts broken over the years (or worse, snapped off ears on the compressor $$$$$).
The rear bolt is hard to get to and people tend to gorilla the **** out of it when tightening or just ignore it altogether.
I was one of those with one of the compressor bolt ears broken off. I can't tell from your description if that is what your issue is, but I'm here to tell you it does happen. The symptom was a un-fixable squealing belt; I'm not sure the broken part was really visible until we got the compressor out.
I ended up replacing the compressor and doing a refrigerant conversion with parts from griffiths.com. At bit expensive but done right.
