Balance shaft covers?
Is anyone aware just how compatible the b/shaft covers are between models? Are the all the same or are did the factory make changes "because we can" through the different models? I will need some for our 968 motor but not sure if we can use from any model. We don't have b/shafts in this motor.
edit: I just went to garage and checked. My covers are stamped 92 so they are 968 ones which means my 2.5L covers are still at LR. Thanks for posting the question I will have to call Mike/Dave. Sorry I guess my answer didn't help.
I believe the balance shaft covers from my 2.5L are on my 968 block. And of course I am running balance shafts.
Rainman
If you aren't running B-shafts then the problem of "mixing and matching" blocks and covers is done away with.
In that case, why not just plug the oil holes (except the turbo feed) and ditch the covers altogether?
Yes, there are a few options. We already have some plugs made up although not 100% sure if they're going to fit depending on which covers we wind up using. May still go with a flat cover too.
Professional Hoon
I would be inclined to use the later ones. i know there are differences how the balance shaft and bearings are held in place, not sure if that will make a difference overall.
To those that run without covers, what did you use to seal up the passages?
Might find something useful here for an idea. I typed in "plug" on their search engine.
https://www.pegasusautoracing.com/ke...ywordButton=Go
M14 x 1.5 is the size of the tread for anyone wondering.
I know that you would not use this fitting to plug the hole...obviously but figured I could take a pic to show an M14 x 1.5 threaded into the cover confirming the size.
The depth on the hole when I just measured it is 10mm
https://www.belmetric.com/14mm-metri...s-c-11_90_871/
This link might be a better source.
