Considering performance upgrades - how would you spend your money?
i'm considering putting roughly $3-4k into my 951 and I'm curious where everyone would put that money. i'm looking for performance (suspension, brakes, steering, mounts, exhaust, etc. all done), so i know part will be the turbo and downpipe (currently stock turbo). MAF and injectors will need to be added. With that level of investment, what specific pieces would you put together? is 350hp at all possible or is the budget too low? what are the 'go to' parts these days for the 951?
You probably saw this link but in case you didn't. Pricing should be available from listed sources.
Hope this is helpful![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
https://rennlist.com/forums/944-turb...ful-links.html
Excellent writeup, but I have disagree with
My car is a daily driven NA with nothing crazy done to it, and it's been the best mod I did to the car hands down. It requires a lot of homework but is worth it, if you are willing to be involved in the car at a very technical level.
The only time you would want to go to a Standalone EMS is when you have a pretty serious race modified engine that you want your engine to do specific things at certain times where it would be harder to achieve this with a piggyback.
I'm in a similar scenario as well with a similar budget.
All maintenance is up to date... Suspension is done.
Now, piecing together go fast goodies...
So far this is what I have so far and still need...
Have
- Used low mile LR Super 53 (from Lart) - $750ish
- Fabspeed 3" catbypass pipe - $600 - bought on sale over the holidays.
- Fabspeed 2.75" downpipe - $275 - bought on sale over the holidays
- Tial 38mm wastegate and adapters - $200 - bought used
- LR adj fuel pressure regulator - $75 - bought used
Still Need
- larger injectors - $150ish - probably Siemens 80lb
- Engine Management / MAF / VEMs, etc, probably going VEMs - $1400ish
- Wideband O2 sensor & gauge
Let me know what you end up going with...
Have
Still Need
Professional Hoon
I wrote it in 2012, A few things have changed, But i still stand with the quote. Not everyone has the willpower to do a standalone on a street car. We have 2 perfectly good products to avoid going standalone. Vitesse and Rogue. The rogue DME is a very capable unit and its basically a standalone.
If you are going to track the car save some money for seat time and coaching.... nothing more humbling than when you make it to the advanced group thinking you are doing pretty well with speed, then every now and then you have a hot shoe in a spec 944 or a spec Miata all in your mirrors waiting for a point by... it's not all about how much HP you have but how much of that HP can you as a driver use, so a friend tells me cause I wouldn't know anything about that
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
Professional Hoon
If you are going to track the car save some money for seat time and coaching.... nothing more humbling than when you make it to the advanced group thinking you are doing pretty well with speed, then every now and then you have a hot shoe in a spec 944 or a spec Miata all in your mirrors waiting for a point by... it's not all about how much HP you have but how much of that HP can you as a driver use, so a friend tells me cause I wouldn't know anything about that ![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
I have a friend who's a very good driver, he went out on track with another friends car after his session. took 5 seconds off his time. same car. different driver.
Just my .02
But also consider packing a comprehensive brake and suspension refresh (whatever is needed).
Bushings, new fluid, new pads, etc.
Clutch hydraulics? Wheel bearings?
Building that into your budget maybe easier on you and your wallet in the long run than letting any problems actually develop.
I think you can do 300+ and knock out a lot of the peace of mind projects as well. Especially if you can turn a wrench for an hour or two on the weekends and piece the projects together one by one.
Have
Still Need
Have
Still Need
how close are you to putting everything together? definitely post on your progress and completion. i'd be very interested in your results also.
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
now, i'm to the point of going after more power and then replacing/repairing what isn't up to the task after that.
So far VEMS pnp has proven to be less hassle to install and get running than the products you are referring. No need for modifying factory harness also.
Runs perfectly with whatever configuration you want.
Mike, with VEMS you don't need WB sensor or gauge. Because WBO2 sensor is already included in the kit and you can see any mixture info on computer screen or android device. You can add some AIM device (like AIM only VEMS multigauge) if you want and display all data in the 52mm gauge (two fields at a time, button changeable), shows everyhting ECU sees.
