Fuel Injector cleaner
Hi Everyone,
I was reading around and came across this, what is your take on this type of products? do you trust it? Do you use it? and if so what is your recommendation? Brand? How often and so forth.
PS I s have an 86 951 with 70K miles
Received 5,402 Likes
Chevron Fuel System Cleaner, ran through prior to every oil change. Buy at WalMart.
Why do you think you need an injector cleaner now? Are you trying to solve a problem, or just proactive preventative maintenance?
I've used BG44k, Seafoam, and the Chevron mentioned above over the years. Now tending to just use Seafoam for winter storage fuel stabilization and water condensation prevention with fuel injection cleaning as an extra plus in the Spring.
The Chevron stuff was recommended to me by a Porsche mechanic at MCL Porsche in Vancouver way back in 94. Interesting it came up 22 years later No Chevron stations in Alberta. DOH!
