Mounting a pt5858
Little to no actual info on grinding the factory mount to make one of these fit (or 6262 for that matter)
Could anyone confirm if all I need to do is grind down the fins beneath the hotside housing?
Broadfoot sells a mount with oil passages modified rewelded etc, and I just want confirmation if the 5858 actually needs that.
This (source - refresh951 garrett install)
![](http://www.refresh951.com/images/mount4450.jpg)
OR this (source - broadfoot site)
![](http://www.broadfootracing.com/Modified_951_mount_1.jpg)
Most of the PTE issues are old and overrated. My 5558 has been working flawlessly for two years now. Make sure you get the ball bearing version, avoid journal bearings. Our engines work best with thicker, high viscosity oil which will also help the turbo live a long life.
Location: Bangkok, Thailand, Milpitas, CA & Weeki Wachee, FL
1 Post
I have it on a stock 2.5L short block, this is the best option in my opinion if you want to keep a fairly stock setup. Possibly would consider the PT-5658 for slightly faster spool.
