28pin DME 951
Hey guys I am looking to see if anyone has a spare 28pin dme for a 951 I can borrow. I believe mine may be suspect and I will turn yours in its proper conditon. Thanks!
Car is shutting off after 30min of running. Does great until then but at that time period it just cuts off and wont restart. Seems to be getting fuel I can bypass the pump and the pump runs but still no start. It will turn over and try but not aftually run. Tach will bounce and everything. Coil isn't hot, tapping on DME before and after makes no change. Shaking reference sensors harness makes no difference nor does DME relay. I'm thinking DME, KLR or reference sensor is getting hot and gling bad. Wanted to try a DME to make sure before spending the money.
I have a multimeter.... fpr and damper both seem to be functioning no fuel in vac lines. Weather makes no difference and was doing it in the summer. Going to bypass KLR tomorrow and see if it helps any.
