New SPEC 944T Clutch Teaser
#46
Location: Bangkok, Thailand, Milpitas, CA & Weeki Wachee, FL
1 Post
Gustaf:
Thanks for the information. I too wanted to switch to high speed Hall, I will send you a PM for more information. Sucks to hear about the set screws in the aluminum wheel, I was liking that idea as it would save a ton of weight. Do you feel the poor signal was do to the factory VR sensor or did you also try another sensor?
#47
Rainman
Gustaf:
Would give a bigger "target".
#48
Yes the ECU can handle any combination.
#50
1 Post
My thinking was to drill and tap for 1/4-28 fine pitch set screws, but have them bottom out with enough height remaining so that when I machine them off flush with the FW OD, it would leave perfectly round 1/4" steel pick up points. That was a mouthful and a run on sentence. I would think this would work fine, but I have no personal experience and looks like Gustaf has already tried this approach.
#51
#53
#54
Basic Sponsor
No pics yet. Maybe tomorrow. What I can tell you is that is has a few hundred pounds of additional clamp load which translates into approx 70 ft. lbs. extra capacity per stage. Those capacities we "should" have tomorrow.
Mike or Dave Lindsey
www.lindseyracing.com
U.S. 1-877-943-3565
Other 1-405-947-0137
U.S. 1-877-943-3565
#55
1 Post
I am running the sync and ref sensors off of my cam sprocket. We drilled and inserted 8 magnets evenly spaced in the cam sprocket for the reference sensors and a 9th magnet where the points used to go for the sync sensor. Makes for a very clean modification and gets your sensors away from any debris. Would take pictures but the engine is in the middle of a re-build.
Bob:
I would be very interested in seeing some pics of this setup. I assume since you are using magnets, you are using high speed Hall sensors?
Thanks,
Eric
#56
Which ECU are you using?
#58
1 Post
Luis sent me a link to Patrick Motorsports last night and the aluminum 968 FW with the 60-2 ring looks awesome! How difficult to fit this to a 951? Is it worth the effort? I have always wanted to switch to the quick clutch swap 968 bell housing anyway. I think George D has done this.
#59
#60
No choice, the pillow block that supports the wrist pin in the piston failed. Blew a hole in the bottom of the oil pan, destroyed the rod on the failed piston and scored the liner. The block was salvageable by boring out the cylinders to 4.165-in or 105.8 mm. LR has ordered me some JE pistons that should be here hopefully in the next week. After pistons arrive I will get the measurements and order some Pauter rods. In the mean time the pistons will go to the machine shop for the final hone. If all goes well I am hoping to have it back on the track by the latter half of February, neither I nor the car will be ready for the Two Step but maybe COTA dependent on when the daughter graduates from her masters program.
I am still in limbo about putting a bigger hotside on the turbo. I will probably see how it runs and get some data points first before making any final decisions. As it will take a retune if I replace the hotside instead of a tweak.
