944 Turbo Front Struts (Australia)
![Smile](https://rennlist.com/forums/images/icons/icon7.gif)
Team,
I'm in need of a replacement set of front struts for my 944 Turbo. There are plenty online for 944's but not for the Turbo's. Can someone please steer me in the right direction so I can purchase a new set or a good set of second hand units?
I'm not looking really looking for race standard just good quality for a daily drive?
New or good quality used would be great!
Please PM if you can help!
Professional Hoon
Mate if you have the coin, i would recommend KW V3 all the way. They are amazing for daily. probably smoother than what came with factory and when you go for a spirited run, the shocks will stiffen up and it will turn better than it ever did.
If not, the Kony double adjustable are great. I had them also, not as smooth as the KWs but still great.
Why not get the Koni yellow sport inserts off ebay, takes a few hours to fit they are adjustable, have used them they are great on the street on their softest setting (I have a cab so to much stiffness is not good)
rgds
mike
rgds
mike
If you're looking for a complete Koni strut, any of the sealed Koni struts, whether for Turbo, NA, S2 or 968 will bolt on. The S2 and 968 will have a smaller lower spring perch because they used a different spring but they'll still work if you us the accompanying spring or switch it to something like our adjustable ride height kit. Buying the 8641-1414 Sport insert may be the best way to go though.
Your Porsche Parts Superstore
![](http://www.paragon-products.com/v/vspfiles/assets/images/pagidrs2.jpg)
![](http://www.paragon-products.com/v/vspfiles/assets/images/Paragon web logo.gif)
![](http://www.paragon-products.com/v/vspfiles/assets/images/konilogobkbgsm.jpg)
Parts | Tech-Session | Facebook | Youtube
Jason Burkett
Paragon Products - Porsche Parts & Accessories*- 800.200.9366
Tech Session - Porsche Tech & Info*- 361.289.8834
jason@paragon-products.com
Jason Burkett
The Koni 8641-1414 Sport takes that into consideration. Here's our DIY Tech Article on installation:
https://www.paragon-products.com/kb_results.asp?ID=50
Basic Sponsor
I have only used struts but if budget is not an issue I personally would go with the Paragon kit best buy for the money.
