The RP968 It's a bit of a thing...
#48
#50
Should be a Sticky!
#54
How simple would you say flipping the head was? Probably couldn't be done in regular 944 Turbo cause of space but I'm very interested. Seems it simplified plumbing and gave much better access to several things.
#57
It's not the simplest thing but not too difficult, mainly fabricating the oil drains. But it's a trade off, we can run cooler intake temps and better exhaust manifold, but the intake manifold is a very tight fit. It's just a small engine bay!
#58
About to send my head out (street car) but I've been looking at these head flip a ton. Also have dual cam gears.
#59
Yes we had a bit of trouble fitting the intake manifold, but the exhaust side and the intercooler set up works really well. When you seal the engine bay it does get a bit hot but our intake temps were within a few degrees of ambient.
#60
Professional Hoon
I honestly don't see the point in a street car. Even in a standard track car.
In Rods case and Patricks, gaining 0.01 of a second could win them the whole race (in class or rods case the whole event)
Also need to think about building the intake to suit + Injectors, new vacuum lines to the intake.
