Gt3582 install
Gt3582 install
Well I decided to bite the bullet and go for a new turbo on my 3 liter
Inspired by Shawns success and McLarenos walkthrough
This is a Garrett Ni resist 0.83 housing
I went with the Broadfoot mount which has a few issues sorry to say first it didn't clear the steering shaft so I had to space it up and out on the motor with 4 millimeter washers second the drain was quite an improvisation basically I use McLarenos drain setup with some mods
But this I'm hoping this is the real coup de Gras I installed a slip joint on the crossover hopefully eliminating that nightmare of fighting with the crossover and manifold
I gave this a lot of thought. No way was I going to spend all the money on a new turbo install without coming up with some kind of solution to the crossover nightmare.
Last time I R&Red that thing I had to take everything loose including the manifolds and pull it back together with the bolts a little at a time. Thing is it's a crapshoot every time, it's always different. I could have gone V band like the Lindsey 2 piece, but you're still having to pull everything back in with bolts.
With this at least I have some vertical and radial wiggle room.
Yep, it's still unproven to me if there will be an adequate seal. But this I feel a slip joint has a good chance of success.
I can always just weld the whole thing back up UGH!. I probably have 20 hrs. in fitting all this together. Man I hope it works.
http://www.burnsstainless.com/dsa-2.aspx
I hope to have that turbo running next year myself. Pretty sure I'm getting slip joints on SFR stage II headers. SFR is doing all the hard work for me though. Looks good!
Good luck and keep the updates coming. I'm updating my turbo now with a bigger KKK style hot side, but watching with great interest and looking for inspiration to go this route on the next motor...
