Injectors
951 injectors are 5.x ohm but wired in batch so DME treats them as low-impedance injectors. When wired individually, some aftermarket ECU's can run them as high-impedance injectors.
1. measure impedance with meter
2. stock 951 injectors are 5.5-ohms
3. resistors needed = 5.5 - (#1 measurement)
For example:
1. measured injectors @ 2.5-ohms
3. 5.5 ohms - 2.5 ohms = 3.0 ohm resistors needed per injector
If #1 measurement is 12.x ohms high-impedance, then subtract about 20% flow-rate from those injectors due to higher latency.
For example:
Yea I just talked to Josh about having the chip remapped for the bigger Injectors. I'm just afraid that I'll damage my computer because the resistance is different
Small Business Partner
