Replacement Aluminum Rogue Tuning MAF tube
Small Business Partner
VMP.
Yes, I am working on that!
yeah, curious as to what all we will need to be up to date. So when we do get the upgrade we will be able to tune/log correct?
Logging is still the same hardware, and works for any M-Tune version:
http://www.roguetuning.com/dme_logger
I can handle that. Send me an email.
[QUOTE=Rogue_Ant;12125597]The new chip daughterboard allows you to Tune with either an Ostrich emulator, or an EEPROM burner.
so if i order the logger now will I get the new software with it? so then all i have to do is get the ostrich, where is the best place to get that?
Asking this here to spread the information - hopefully this will answer others questions too:
* Does the new chip board mean you no longer require the DME for modification in order to use the tuner?
* If I order the tuner package thru your website, will it come with an Ostrich emulator?
* I already have your logger. Is there a new version of the logger to go along with the chip board? And I would just need the new chip board for tuner capabilities?
* Is there a way to purchase the chip board alone (would you prefer I purchase the chip board alone and get the Ostrich myself)? Personally, I would just assume order the tuner kit from our website and get the chip/board and emulator all together at once.
* If I want to run the Ostrich emulator, does this mean I'll be running two boxes (logger + Ostrich), or does one of the boxes (Ostrich?) provide both tuning and logging?
* Tuning with EEPROM burner: please expand on this - I imagine something like I log files, look at them off-line and adjust tune, burn the new tune in the EEPROM, log again, etc. ? But this seems like it would require additional features in the logger (or maybe features I haven't seen/used yet)?
