Replacement Aluminum Rogue Tuning MAF tube
Looks good...but the transfer function is going to be different. The tube is quite important and very small changes can have a pretty big impact. Do you have the tuner? I think you are going to need it.
Professional Hoon
I went though this not long ago. I also spoke to josh about numbers ect.
I made one, to exact specs. The plastic MAF tube isn't exactly round (by ~2-4mm) so my aluminium tube couldn't get the right flow though it to replicate the original one. we also tried to bore out the aluminium one further.
I can see that you need the modified one. Good luck, but you'll need the tuner also.
Project looks really good. Hope we can meet up sometime this Spring.
Small Business Partner
But the MAF sensor is different... As is the transfer function.
