Big Blue Saw
$22.44 per bracket, but I ordered 5 since buying a single one cost nearly as much as 5. I used seriously thick aluminum too, so probably costs less with more traditional 14-16 gauge steel. You can use their sample file to get a sense for the pricing of different materials and quantities...
You have to add a few files. See this thread:
http://forum.freecadweb.org/viewtopic.php?f=3&t=6009
Also, don't bother with what units are displayed (which will be mm by default). Just design in inches and ignore the indicated units. So if you want something to be 25.4mm long, for example, enter it as 1 (even if it shows as 1mm when designing)... The big blue saw system will read that as 1 inch (25.4mm) -- at least when using a freecad DXF export. The Big blue saw has it's own simple online cad system too, which I didn't try but looked very easy/simple....
Looks like just over $210 for a single 1/2" 6061 bellhousing adapter. $150 if I do 3/8" 6061. $200 for 304SS 1/2"
Super reasonable, especially for one-off singles.
copper gaskets?
https://rennlist.com/forums/944-turb...ml#post9139505
I had already mentioned to Ed about doing that. Big blue saw shows 1/16th copper, which should be good. I often see copper gaskets listed as annealed copper, so will look into that... Should be able to get the cost down to a fraction of what those gaskets cost retail. I'm thinking the triangular downpipe, and the square one between the cat and muffler -- and maybe cross-over to turbo? Any others worth making?
Rainman
Think anyone could make some intake manifold flanges for 8v/16v? Maybe just add injector bosses later?
![Lightbulb](https://rennlist.com/forums/images/icons/icon3.gif)
Don't bother with PNG if you're trying to do something accurate. Use DXF instead. Here are some hints for formatting files for use with Big Blue Saw:
http://www.bigbluesaw.com/saw/faqs/f...-blue-saw.html
