Big Blue Saw
Old 02-25-2015, 09:25 PM
Tom M'Guinn
Tom M'Guinn's Avatar
Default Big Blue Saw
I found this water-jet cutting service online and thought I'd share.
http://www.bigbluesaw.com/
It's a very slick way to make flat brackets, flanges, etc. (or brackets that can be cut flat and bent to final shape). You just upload your cad drawing, pick a material and thickness, and get an immediate quote. The brackets I ordered were in the mail within 2 or 3 work days after ordering. The resulting bracket was spot on to all my cad measurements, and the holes are at least as good as drilled holes -- perfectly fine for tapping.
The bracket I did is to hold the big MSD coil, along with a custom rectangular catch can. I still need to tap it and powder coat, etc., but was so happy with the bracket I wanted to show it off and promote the Big Blue Saw a little.
Old 02-25-2015, 09:32 PM
StuckIn86
StuckIn86's Avatar
Old 02-25-2015, 09:34 PM
Jay Wellwood
Jay Wellwood's Avatar
Great stuff.
Can't beat water jet cutting for precision and smoooootttthhhh parts.
Old 02-25-2015, 09:39 PM
Crazy Eddie
Crazy Eddie's Avatar
Man that is a heifer of a bracket
No flimsy metal here ....
Nice
Old 02-25-2015, 09:55 PM
Tom M'Guinn
Nice
I wanted to make it thick enough so I could tap the mounting holes, to avoid nuts that are otherwise hard to reach, and have it sturdy enough to hold a full catch can -- but it's probably over-kill with 1/4" 6061 aluminum. My DIY bracket for the MSD box is at least as sturdy
Old 02-25-2015, 10:46 PM
Simon Arthur
4th Gear
Simon Arthur's Avatar
Hi Tom,
Simon from Big Blue Saw here.
I'm glad this part worked out for you, and thanks for pointing the rest of the forum in our direction.
Let me know if you have any questions about our service or waterjet cutting in general.
Old 02-25-2015, 11:05 PM
Paulyy
Professional Hoon
Paulyy's Avatar
water jets are generally good. Was going to purchase one. but headed in a different direction.
glad it worked out for you.
Old 02-25-2015, 11:32 PM
V2Rocket
Rainman
V2Rocket's Avatar
how does one obtain suitable software
Old 02-26-2015, 12:06 AM
Paulyy
Professional Hoon
Paulyy's Avatar
Jump on their website. tells you.
but search cad programs. heaps around.
Old 02-26-2015, 12:12 AM
Tom M'Guinn
I use this:
http://www.freecadweb.org/
Old 02-26-2015, 02:34 AM
Crazy Eddie
I assume your going to power coat that bracket ??
I could make it real shinny for ya if ya like
Old 02-26-2015, 10:29 AM
Simon Arthur
4th Gear
Smile CAD Software
You can find a bunch of good FREE or low cost CAD software listed here:
http://www.bigbluesaw.com/saw/faqs/f...-blue-saw.html
Old 02-26-2015, 12:32 PM
alxdgr8
alxdgr8's Avatar
Cool site! Will definitely use it in the future for some projects.
Old 02-26-2015, 12:43 PM
alxdgr8
alxdgr8's Avatar
Originally Posted by Tom M'Guinn
What format did you use to upload to BigBlueSaw? DXF output isn't working right for me with FreeCAD and the website doesn't load when I try and upload a PNG.
Old 02-26-2015, 01:28 PM
Tom M'Guinn
You have to add a few files. See this thread:
http://forum.freecadweb.org/viewtopic.php?f=3&t=6009
Also, don't bother with what units are displayed (which will be mm by default). Just design in inches and ignore the indicated units. So if you want something to be 25.4mm long, for example, enter it as 1 (even if it shows as 1mm when designing)... The big blue saw system will read that as 1 inch (25.4mm) -- at least when using a freecad DXF export. The Big blue saw has it's own simple online cad system too, which I didn't try but looked very easy/simple....
Quick Reply: Big Blue Saw
