making sure im doing the right thing.....
I never notice, anyway
ok im about to buy a new bov, but want to make sure that im making the right decision.
i can make boost, but it seems like im down about 30 hp (butt dyno). at 1.2-1.25 bar, i get a loud rush of air from under the hood (cant listen under the hood as the only time you can make boost like that is under load, and i can just hop on a dyno for free to use its load. anyway, please reassure me that my diagnosis is correct.
i was told to pull the vacuum hose to see if the pressure bleeds down to see if it was the bov, but i have no pressure gauge, and did not really even understand the instructions anyway. if i take it off the car can i tell if its ok or not? like opening it up? and how?
thanks!
thanks!
i wish i did, if i pull it off the car, what am i looking for? (not identification of the bov itself, but what about it am i looking for?)
I second the vote for a loose or cracked intercooler hose. My identical symptoms were caused by a loose hose at the turbo outlet (hardest to see, hardest to get to, highest heat.) Remove and check all four rubber turbo-intercooler-manifold hoses.
To check the BOV, suck or blow on the small inlet port. If air leaks in or out, the valve is bad and needs to be replaced. You may want to do this in the privacy of your own garage!
