m-tune tuner/logger
#31
Originally Posted by Rogue_Ant View Post
I expect that it will be supplied with all optional maps populated... the idea is to make the kit even more universal, so if you have a 2.5L and later switch to 3.0L that the Map is already there, no need to for a chip-swap. Same thing if you wanted to try E85 vs race gasoline.
Furthermore, the Maps are now open, so the functionality of my DME Tuner setup is being built-into the new chip, and will come standard (you just need to be able to burn chips or get an emulator to take advantage of the open hardware).
Do you have a recommendation on the emulator? Is this any good? -> eprom emulator ostrich2.0 from moates.net Was recommended on an E30 site for motronic
#32
#33
Small Business Partner
On the back-burner, but I'll get back to it at some point...
Hmm, I think that will be handled through LR.
You are not stepping on my toes ![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
I believe LR is taking pre-orders now. We are working as fast as possible to get everything done.
As Shawn said, the Ostrich2.0 is the one to use.
Thanks for the compliments!
Don't want to step on any toes, so only if Josh doesn't do this anymore...
I could help out on the conversions. I have 3 decades experience with electronics, have a recent J-STD-001 soldering certification, and have worked on electronics launched off military aircraft. And I've done several of these conversions all ready.
Like I said, I'd be happy to help out but only if appropriate and not stepping on toes.
#36
I have both the logger and tuner. I want to log from my race car. Anyone think of a good solution? I tried a 7" windows tablet but tuner pro does not work well on it. Mounting a laptop in the car does not sound very safe
