Cracked block repair thread
I did $13,000 of mods on this car. And ran 2000 miles and I cracked the block. It's time to put it back together with a new steel sleeved block and a different engine management etc.Attachment 897182
Can someone tell me the best way to stage the car to pull the motor and put a new clutch in it. I'm assuming it should be on blocks if so how tall etc. all help is appreciated
24" is plenty of room. Sorry to hear about your motor, everyone around here knows huntley is junk. I'd recommend going with megasquirt if you are interested in doing EMS. I have a very good thread about installation and tuning floating around.
Good luck with the swap!
A guys here in the Netherlands has a plug and play EMS; VEMS. It bolts right onto your harness and it's even better than Megasquirt and really not expensive!
http://www.dp-engineering.nl/
Good luck!
Good luck!
I am going to go throught the moded parts and see what I have, i will take PHOTOSs etc, Hopfully with this thread I can identify the parts to figure out where to go next , before I pull the triger I will know what I am up against. I was one of his last clients and have no idea if i got what I paid for and what will be the best conclusion using what I have.
All help and advice is apreciated
here was the build list
stage 3 mass flow
stage 3 turbo
upgraded fuel pump
he gave me dyno charts showing 380 @ the wheels
arc 2 ?
larger injectors
chips for computer
tial wastegate dual port ?
head was oringed and suposubly bench ported ? all new...big $
replaced windsheild and got ac working
total bill was 13k
stage 3 mass flow
stage 3 turbo
upgraded fuel pump
arc 2 ?
larger injectors
chips for computer
total bill was 13k
Good luck!
Good luck!
I used cinder blocks/ramps to do my clutch, pics in this thread:
https://rennlist.com/forums/944-turb...mps-etc-2.html
but since have built wooden blocks to replace the cinder blocks (excuse crappy cell phone pic):
If I need more height, I can still put the ramps on top of the wooden blocks. Very stable and plenty of room to work, albeit a bit of a pain to get up on the blocks.
update
I have decideed to go ahead with project m the car has been in hybernation for five years. when i had it running it hauled ***, way faster than I will ever need. I turned the adjustable boost dial one day while racing and the boost shot up to i dont know how muchm definatly past 22.....the car was tuned on a dyno to 18 psi, I was given the charts etc....I did many boost cycles at 18 and it overwelmed the suspension......I will be happy at 16 p.s.i.....so I am going to use what I have if it all works again.....I will transfer everything over to the steel sleeved block...All i need this car for is a comuter to my basecamp...I have no interest in racing etc..
Basic Sponsor
I have also offer him the option of Lartstardize the car but back up on me
