Its allways somthing
Most of you know, I just had a 2.8l done with many mods. I have about 600 miles on her , other day intercooler boot came loose no big deal..... I drive it to my shop ten mins away, find good amount of oil in my charge pipes , front mount even the turbo charger .. after checking over every thing looks like turbo seals, spent 5hrs on a Monday after work removing it . still under warranty I sent it back to charile awaiting information
Sorry did not see comments yes its a speed force .. and thanks. . Also no catch can . The seals went bad in turbo should have back on tuesday. Said from braking in the motor the metal shavings tore up the seals. My engine has only 600 miles . Did a 2.8l build
Alusil or sleeves?
I hope the bores are ok. Which pistons did you use?
Aren't you the guy who is onto his 2nd or 3rd LR motor...or is that someone else? What are they saying about this? That's 'Break in' btw.
