View Poll Results: How much boost?
10-12psi
1
2.44%
13-14psi
1
2.44%
15-16psi
13
31.71%
17-18psi
16
39.02%
19-20psi
4
9.76%
21-22psi
3
7.32%
23-24psi
1
2.44%
25psi +
2
4.88%
Voters: 41. You may not vote on this poll
How much boost are you running?
Old 12-12-2014, 08:34 PM
blade7
blade7's Avatar
Any pics of the copper gasket and Beru sealing rings and is the head or block machined for the rings ?
Old 12-12-2014, 08:36 PM
blown 944
blown 944's Avatar
I'm sure we will be looking back in 5 years wondering why we stuck to the 8v. I've already asked myself that a number of times. I keep coming back to simplicity and that I don't need any more power really. It's just nice to have.
Old 12-12-2014, 10:30 PM
333pg333
333pg333's Avatar
Rather than skew Paulyy's thread too much more here's a link to some pics etc.
https://rennlist.com/forums/944-turb...l#post11872521
I've no doubt that the 16v would be a significant leap forward Sid, but as you've seen yourself, the 8v is still 'Ok' in some respects. If it turns out that I can't get away with keeping my current pistons in the rebuild then I may still go with the 16v S head that is also on offer. Nice to have alternatives.
Old 12-12-2014, 10:58 PM
Zeff
Zeff's Avatar
18psi. I need to send my ecu back to josh so i can run race gas and bump it up to 22
Old 12-13-2014, 10:19 AM
running_cold924
running_cold924's Avatar
16lbs. Enough power for the streets....also want to do some tuning so I need the tuner from Rogue
Old 12-13-2014, 01:31 PM
eman930
eman930's Avatar
17 because I run outta fuel
Old 12-13-2014, 02:59 PM
black944 turbo
black944 turbo's Avatar
I normally run around 13-14 psi. I used to run 15 psi, however my but dyno did not notice any change in power by dropping it.
Quick Reply: How much boost are you running?
