white powder in engine bay
I noticed there is a powder-like residue on the coolant hose at the back of the engine bay, and also on the heat shield and the exhaust around that same area. Any ideas what that could be? It feels very dry to the touch.
You might have an exhaust leak coming from your #4 exhaust manifold header ?
Its hard to tell from the picture
The headers can leak under the shields or right at the meet of the block and header
Good luck
Regards
Ed
Good luck
Regards
Ed
Does that usually deposit white powder? I know this might not be clear from the picture but it's very concentrated in the area around that coolant hose. It's quite noticeable and while I'm not sure how long it's been there, it's not normally there (I inspect everything in my engine bay fairly often). But if an exhaust leak could be the cause, that might make sense because I tried to remove that test port a while back, which goes into the crossover just below this area, and I couldn't get it out of there, but with the flare nut loosened it might have started to leak.
It's probably that ..... I would just remove it and believe it or bot if you have an extra lug nut they fit right on top of that test port to seal it off
Why couldn't you get it off ? Heat the pipe up for a few mins with the engine running then spray some PB blaster and wait a while and go at it. It should come right out . Make sure you have a nut to put over the test port before you do this ....
Regards
Ed
ps btw you need to clean that engine up a bit
I was going to say the test port, but the pipe was there in the picture....
Regards
Ed
Regards
Ed
I did use lots of Kroil but I can't remember if I tried it with the exhaust hot...I'll try that next.
Yep I have a spare lug nut for that. I loosened the flare nut but the tube just wouldn't come out. It's hard to get a decent grip on it by hand and I didn't want to pinch it with anything that might make it break off...then I'd be stuck with a leaking tube that I couldn't remove
With a little wiggling it should come free ... Mine came right off. In fact the metal tang at the top broke off on its own...
Good luck
I believe aluminum oxidation would be unlikely considering the material where the powder is present (steel, rubber, painted surface of the body heat shielding on the frame rail). I wouldn't worry much about it. I've had many exhaust leaks and have only ever seen black soot with the occaasional tan, nothing white.
