INTAKES: What do you run or are building?
Thanks Fred. Yes, see you there barring any mishap.
Getting closer...
Getting closer...
66mm. We had that already and didn't want to go massively bigger anyway.
Rainman
but how will you fill the oil
as far as intakes go...this is a "Sid special"...maybe its not pretty but it should work pretty well. short runners and big box, i have no concerns for flow distribution. box is about 17" x 3" x 5" if i remember correctly...about 4 liters internal volume.
Happy for anyone to post pics in here. Want it to be a reference thread. Also include before and after dyno charts if available. Hopefully I can do this tomorrow.
Thanks...I'll look into it.
Don't have the charts yet. Soon. But we were able to make some small gains down low and flatten out the top. Looks like we're making the same power at about 3psi less. Wound it up to 26psi and made 548whp on a conservative dyno. No sign of coolant leak either which was very pleasing from the new gasket/ring setup!
