arc 2 no start
recently figured out that previous owner installed a Huntley MAF kit along with the arc 2 fuel system in my 86 951. I took the dme and klr apart to see what chips were installed as well. after putting everything back into the passenger footwell, the car wont start and just cranks. i am not seeing any power to the arm 1 or arc 2 systems in the glove box, so i suspect an issue with the wiring. does anyone have experience with installing one of these and where they are spliced into the wiring harness for power?
Basic Sponsor
I don't know if there is anyone alive on this board that can remember how to tune or install the arc2. Have you tried pelican forums?
Not so fast.... ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
The arc2 is made by split second, and if you go to their website they have install instructions. For simple power hook up, however, most people just tapped the power line going to the DME, and if memory serves that's how Huntley recommended doing it.
Basic Sponsor
All dead except Tom, lol
thanks for the replies, it was my own fault not mounting the dme/klr assembly back into the footwell properly. once a proper ground was made the arc 2 came to life and the car started. it did act really weird for a while though, running really lean on idle...dont really know what that was about. also doesnt seem to be running in closed loop - is this because dme is still learning a/f mixture?
I did same thing last night. Fitted Rogue ECU, wouldn't start, so put old DME back in and still no start, and then it dawned on me that neither unit was grounded because I didn't mount the bracket to the car. When I realised my mistake, I fitted Rogue ECU back in and it fired first time. Glad to know I am not the only one who made that mistake
CRS?
