Less timing = more power? Post your timing maps
I think for awhile I may have been running way too much timing on my car. I switch off betwen E85 and 93, mostly corn but I run pump when its all I can get. My corn map is pretty dialed in, my gas map, perhaps not.
I had been running ~22* at peak tq, with a pretty normal looking gas curve. Today I filled up with pump and pulled about 4* out of every cell over 3k rpm and above about 8 psi, and it definitely pulls harder. I'm sitting at 18* at peak tq, under 23* above 11.5 psi, 27* at about 8 psi, and 32* at 6 psi. Seems to like less timing better.
I thought you changed fuel too. What prompted you to reduce the timing? If you gained power doing nothing but reducing the timing, then I'd worry you were knocking with the extra advance and losing power. Do you have any way to detect knock? How are you tuning? Your best bet would be to find a load-controlled dyno and tune each cell -- adding advance until you peak power then back off a tad (to wildly oversimplify)...
Coupla thoughts, Doug. First, and you know this, but a reminder. Seat of the pants can be misleading.......placebo effect and all of that. Second, given that it is so hot out, you should be more knock limited. These engines have big dang bores, which is bad for knock tolerance. I want to think you have an aftermarket PCM......do you have an active knock control?
Power usually will become flat at a certain point. "MBT" is the term used in industry, it stands for "Minimum timing for Best Torque." MST is the same, but specified (i.e. part throttle). Taking out timing, and gaining power is not typical unless one is knock limited.
......I think its possible I was over advanced past MBT in the upper rpm-boost cells. I say this with the full implication that it was probably absolutely knocking. The butt dyno can't be trusted, but is it possible that that is true? I pulled timing really just for peace of mind. On the other hand, on my ethanol tune I have still yet to find MBT, I keep adding timing slowly and it just keeps getting faster.
I know a lot more about fuel. LBT (Leanest for Best Torque) is around 13.0:1, it stays flat until about 12.0:1, then you start losing power after that. But it is more common to adjust that than it is to adjust timing......like I said, bad things happen when you get too advanced. But in the ignition world, you put in 108RON fuel to make sure you aren't knock limited, then advance until you see no gain, then set your ceiling with that.
Does the corrected table I put up in the first post seem ok to you? I think its probably a safe tune now, as for AFR's I'm seeing 12.5:1 high load vacuum, 11.7:1 in boost. Again this is on pump 93, my ethanol map has had a LOT more driving time and is much more dialed in.
If you advance the timing until the no-gain point with 108 octane, how do you know if that level of advance is within the knock limits of lesser fuels?
Off topic edit: Harry, with respect to RBT being at ~11.8:1, I assume then its no coincidence that I get the most stable idle (lowest manifold pressure) at 11.8-12:1? Its significantly better than 12.8 or 13:1. Does this imply that assuming we had 130+ octane fuel and detonation was impossible, that an engine makes peak power tuned for rich best torque vs lean best torque?
You don't. That isn't the point. The point is to determine optimal ignition timing of the ENGINE without any limits. All of those points will be determined wiht 98RON or whatever fuel. But to determine the upper end, you run it with super high octane stuff so you don't risk blowing up your several hundred thousand dollar prototype engine!
Quantitatively you can not, but its a very good assumption that its not. E85 burns slower as well as being higher octane, these are qualities that cause MBT to vary with respect to the fuel used in the same engine. MBT on E85 would knock on pump fuel, in most engines I suspect.
RBT and LBT would be the same point.......BT being "best torque," and from stoich, you enrichen until you stop seeing gains to find LBT. Then you keep going, and it will be hte same, until you start losing power, at which point it is RBT. But RBT is not really even a term that is used, because it doesn't matter too, too much. That said, since turbos use enrichment for charge cooling to give robustness against detonation, it probably is worthy to know. I ran my old turboford at 12.0:1 (factory was just uner 10.0:1), but my EGT's were so hot that I destroyed a turbine housing in about 10,000 miles.
I owuldn't expect it to be related. What size injectors do you have? Could it be that while idling the injectors are dipping into the non-linear region at stoich, but become mroe stable at richer mixtures?
