View Poll Results: Can you use them?
Yes
![](https://rennlist.com/forums/images/polls/bar2-l.gif)
![](https://rennlist.com/forums/images/polls/bar2.gif)
![](https://rennlist.com/forums/images/polls/bar2-r.gif)
![](https://rennlist.com/forums/clear.gif)
1
8.33%
No
![](https://rennlist.com/forums/images/polls/bar3-l.gif)
![](https://rennlist.com/forums/images/polls/bar3.gif)
![](https://rennlist.com/forums/images/polls/bar3-r.gif)
11
91.67%
Voters: 12. You may not vote on this poll
Bent valves.. un bent.
Professional Hoon
Okay, good, so now I can say what I really wanted to. What are you, STUPID, for wanting to re-use a damaged valve that opens and closes at a rate of over 100 times per second, in an area where it'll see temperatures of probably 2000 degrees!? Risk $10,000 to save $50?
Yeah, re-using them would pretty much be the height of stupidity.
Basic Sponsor
Not bad Australia did a great job
But the Aussies put up a better fight against the Dutch than Spain did... how funny would it be if the defending world champs and 2 time Euro champs loose to Australia, and leave this tournament with three losses? But Australia will miss a couple key players due to yellows, right?
fun so far. I am now a Dutch fan, and that Mexican keeper - wow. game of his life against Brazil.
sorry for the off topic.
I've thought about this, and I have this to say...The worst you have to loose is a broken valve down the road and then you'll be replacing the valves anyway, and you're out a headgasket and your time. Absolute worst case is you kiss a piston. Or....you could run them forever and they could be fine. You could just toss em back in I suppose, but the engineer in me still says the bent point is a stress riser...just cant say for sure if/when it will become an issue. I'm crazy and a cheap bastard to boot, I'd at least consider throwing em back in and seeing what would happen if nothing more than for ****s and giggles.
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
Basic Sponsor
