Opinions/options on Wastegates upgrades
Old 06-05-2014, 05:57 PM
rlm328
rlm328's Avatar
You really don't need anything bigger than a Teal 38.
Old 06-05-2014, 06:09 PM
Sixline
Sixline's Avatar
I got my TiAL F38 from ATP Turbo for $234 plus $15 shipping. If you add the $133 for the adapter plates from fejjj it's still cheaper than the F46.
Old 06-05-2014, 06:53 PM
fejjj
fejjj's Avatar
I have 3 sets left!
Old 06-05-2014, 10:16 PM
GasPowered
GasPowered's Avatar
Question...
Does a larger wastegate have an effect on spool response? ( eg. does a larger wastegate equal a quicker spool up?)
I'm pretty much all set to get a TiAL F38 (I have fejjj's adapter plates), just curious if I should go bigger for faster turbo response.
Sorry, I'm not trying to thread jack, but I'm very interested in this subject as well.
Cheers
Old 06-05-2014, 11:05 PM
George D
George D's Avatar
Originally Posted by BoostBuggy
Any thoughts/comments on the Synapse WG's?
The Synapse I attempted to use wouldn't allow my Profec electronic boost controller to regulate the boost pressure. Synapse, then, forced manual boost control by using differing spring rates! PITA. Sold it, and am a happy Tial user again.
G
Old 06-05-2014, 11:06 PM
George D
George D's Avatar
No difference.
Originally Posted by GasPowered
Question...
Cheers
Old 06-05-2014, 11:18 PM
dmcampbell
dmcampbell's Avatar
TURBOSMART 37mm SmartGate with Fejj Plates!
Old 06-06-2014, 02:03 AM
GasPowered
GasPowered's Avatar
Originally Posted by George D
No difference.
OK, I can appreciate that.... Then why go to a larger wastegate?
Cheers
Old 06-06-2014, 03:15 AM
Sixline
Sixline's Avatar
Cheers
Boost creep.
Old 06-06-2014, 03:24 AM
Paulyy
Professional Hoon
Paulyy's Avatar
Cheers
Larger wastegates are for running lower boost, bypassing more exhaust from the turbo.
For example you'd probably use it on a higher compression N/A with a turbo running 5-7 psi you wouldn't need the turbo to work hard so it'll need less exhaust gas.
We want more boost because of the low compression engine so we don't have much exhaust leaving the turbo.
Old 06-06-2014, 08:09 AM
CBRE
CBRE's Avatar
I have a used Tial 40mm gate and a new set of adapter plates, never got around to installing, $280 shipped
SOLD!!
Old 06-06-2014, 10:47 AM
67King
67King's Avatar
Originally Posted by Sixline
Boost creep.
One of the interesting/funny/peculiar things about wastegates is that the higher the boost level, the smaller the wastegate requirements. Because of just that.
Old 06-06-2014, 01:13 PM
Mark924S
Mark924S's Avatar
i have an mvs38, it was a bit of fab work to get everything to sit pretty. its is a physically smaller unit than the f38. I didnt bother with the water lines, and really like the difference between the worn out stocker.
Old 06-06-2014, 02:12 PM
BoostBuggy
BoostBuggy's Avatar
@cbre, PM sent
Old 06-07-2014, 08:12 PM
BoostBuggy
BoostBuggy's Avatar
Well decided to go with CRBE's 40 mm Tial. That seems to be the least expensive reasonable solution. That and the completely rebuilt K26/6 turbo will be installed at the same time. Will probably still be a couple of weeks down the road but I'm really looking forward to getting the new pieces installed.
Thx to all for all the suggestions and help.
Michael
Quick Reply: Opinions/options on Wastegates upgrades
