Timing belt slipped bent valves.
#31
Professional Hoon
Sorry to hear this. but sounds like u got it under control. At what point is an upgraded head needed? Who's the best for this lr have some flow numbers on there's can't find much less. What's the deal with use n/a head or valves? Under stand there larger but you lose the ceramic exhaust ports
IMO, for head work, your biggest benefit is lower boost for similar power. if you have a custom cam, you can achieve a better torque curve (more flatter) I don't really see many touching the exhaust ports though. just the intake.
#32
Professional Hoon
pulled the cam tower off to have a look at the valve retainers and springs.
Springs look good.
Retainers are intact (thankfully they're titanium!!)
Dont mind the coolant, that happened while bleeding!
Here you can see the springs, retainers ect (i didn't realise the photo was blurry!)
Here you can see that the intake valves are stuck in (probably hitting against the head)
And here you can see the intake valves are not closed
Springs look good.
#33
That really sucks! If it is any consolation an 8V head is much less work than my 16V head...
While having the head off why not take the time to make everything easier to service? Install a vacuum station, then you can clean up the vacuum line mess. I replaced my exhausts studs with bolts and the studs fit perfectly for the intake
#34
Professional Hoon
haha thanks! i've got a mate who did a 16v one.
Well really everything is changed. i have a couple of things that will get changed, but everything was done when the engine was out.
#35
Basic Sponsor
Pauly, are you considering a new head or are you going to rebuilt that one?
#36
Professional Hoon
Louis,
this one will be getting rebuilt.
It's been built by Dave @ CEP. larger intake valves, Titanium retainers, the works. It's been quite heavily ported also. It would be a waste if i ditched this head.
I may not even need valve guides, the valve stems look straight from inspection, i think the valves are just bent and hitting the head.
#38
Professional Hoon
Elliot, Nothing to add really, we all know the problem!!!
Oh the fridge is full, let's not worry about that.
Tomorrow will need to get the car on blocks. Don't have jack stands. so going to do what i did last time (works really well) and jack the car up onto some wooden blocks and put stoppers on the rear so it doesn't roll.
I'm going to try remove the head attached to the exhaust manifold.
#39
If you can, that is definitely the best way to remove the head. I've done it both ways. FWIW, I'm doing even more work on mine beginning today, so I feel your pain! My fridge is full as well!
#40
Professional Hoon
Might crack one open. I've got the car on blocks (don't have stands) but it's not high enough!! I've drained some coolant (not all, what for..)
now i cannot fit under the car.. great. if i can undo the exhaust collector flange. The head will come off.
#41
Professional Hoon
Got it!!
4 bent valves. 4 slightly marked cylinders.
Slightly marked, i'm just going to smooth them out with the dremel and be done with it. replace 4 valves. make sure they're seating. done.
Going to replace the heater valve while i'm there. Noticed some leaking around the join. a couple of hoses will get replaced while i'm there.
Gasket kit (i think it's cheaper getting a new kit then a few bits. & nothing wrong with spares!!)
#43
Professional Hoon
Only problem is, they're custom!! I actually can wait to fix it. Taking my time with it. probably an hour work every day. Taking care of the 2 leaks i had. cleaning up all the coolant that went everywhere.
#44
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Check you valve stem size - there are not many vendors (pretty much none) that make Valves in the same diameter as stock. Ferrea can't supply them. You may have custom valve guides - that's the common way to fit other valves.
BTW - that's a lot of carbon build up for a 'performance' engine - normally that's a sign of bad guides but I would guess that your head is not that old.
#45
Professional Hoon
I'll be measuring when i pull the valves. one of these days. They're oversize valves, not sure how much bigger. But Dave will be ordering them for me. He knows what ones he used.
The head has been in use for a year now. There's more carbon on the cylinders then the head. It's like a fine later of carbon on the head. comes off when you wipe it with your finger
How would bad guides cause carbon?
