The Next Big Engine
#61
Congrats sounds like is going to be a monster
Good luck
Regards
Ed
Good luck
Regards
Ed
#63
Not sure I understand your logic regarding controlling boost.
You want to use the softest WG spring to be able to smoothen the boost curve with the solenoid. The stronger the spring pressure, the more the solenoid will have to work to smoothen the curve between the moment you begin to build boost and the moment you reach peak boost.
The boost controller is integrated with the MAFT Pro unit. It's easy to use. I paired it with a MAC solenoid.
#64
Rainman
ohh that sounds meaty.
just reading that might be enough to make me do one of these.
#65
I did some mild porting while the head was off, had a 5 angle valvejob done and installed all new valvesprings since the old springs had sagged a little.
OK here's the dyno chart with HP and TQ on the same scale. It's a nice, broad power band.
#68
I did a deck plate and used ductile iron sleeves to bore it to 4.155. I used the same crank and rods from my 2.85.
It's running great. I've went 125 plus at 14.8 psi, babying it off the line. Gonna try to hit a low 11 tomorrow night. It's been 11.52 so far.
This engine is awesome. I did a lot of headwork and got close to 250 cfm out of it.
It's a blast to drive wherever I want.
How aggesive have you been with timing? I picked up a ton with some aggressive timing (on E85 always though)
#69
#70
That's low timing. I'm over 30 degrees after MBT. IIRC it's around 37 degrees at 6k.
My logger/tuner is still acting up so I'm using the 2.85 tune still. Seems to like it.
IIRC we are around 21 degrees at 4k
I picked up close to 10 mph by adding at good amount of timing lead. And fuel of course.
They are a far cry from DSM's in regards to ignition timing.
#71
Yes, timing is very low even for pump fuel. Standard M Tune map has it at about 27 degrees at 5700 with pump fuel. Huge difference between 17 and 27 degrees on these motors which love timing after peak torque.
#72
#74
