Hp/tq gain question.
#46
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Personally, I think you guys are very optimistic... I've dyno'ed several turbos, and found that a stock car will make about 200 WHP. You can see on this chart that it took quite a lot of extra boost to make 250 whp (and that's a good running car (technoduck)).
FWIW, I've had nearly a dozen 951s on my dyno - all with different mods - and none have broken 300 WHP.
To the OP, I'd say you're at 200 WHP now, and with a chip - and your other stuff - you'll get up to 220 WHP.
Seriously - unless you have tested a lot of 944s keep away from 'guessing' at HP levels. Way too much SWAG numbers out there.
BTW - a K26/6 is capable of a lot of torque, it can make well over 20psi in the midrange RPMs. at the top end (RPM) it won't do well.
#47
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
This is a totally stock internal 944 turbo (my original 944 turbo). it does have many external mods - turbo, standalone, wastegate, blowoff, inetcooler pipes, injectors and some other details. But - the internals are stock as assembled by Porsche.
So, yes, you can make a little more than 200-250 on stock internals! BYW - this was on a Mustang Dyno - up to 10-15% lower than a Dynojet.
#48
That's a good results. Afr around 12.5/12 which is prob why your making good power. Not rich for safety( error )
What turbo
What turbo
#49
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
I have done a lot of testing and the power does not drop off much as you add more fuel past 12:1. The cooling you get from vaporizing the extra fuel in the cylinder can help on an engine that is not well tuned - but the long term effects of running over rich is not good. Too much carbon build up and oil dilution.
#50
These were from 2010...
The green, technoduck's car, had quite a bit - certainly exhaust, chips, and so-on. I think he had a different turbo, too. I don't recall if he had the AFM or a MAF, thought.
The red was a 100% stock car.
And the blue was my turbo, which had chips, LBE and 3" straight pipe exhaust.
For what it's worth, here is the chart Van made up for me a few years ago. Same mods as Techno Duck, but a 2.5" exhaust at the time. At another dyno day, virtually every car with bigger turbo, exhaust, etc made within 10-15hp of these numbers.
#51
If I recall correctly Technoducks car had a 60-1 turbo, MAF, exhaust, wastegate, and MBC - the usual stuff.
Looking at that chart looks like the 60-1 turbo might not be a good match. at 4700 for full boost
#52
What cause the slight drop at the end? Is that fuel delivery? Or is that perpous part off the tune.
I can monitor my af via android app. What sort off figures do I not want to see on boost 10? 11?
#53
I don't know why the dyno shows the boost plot like that - I have 18 psi by 3,700 rpm according to my VDO boost gauge. I agree that I have exhaust leaks, but nothing too serious. I spent a bunch of money and time replacing the headers, crossover, crush rings, etc a while ago in an attempt to fix it, but it had minimal impact. The only spot that even leaves evidence of a leak in the whole system is the #4 exhaust header flange at the cylinder head...
https://rennlist.com/forums/944-turb...t-today-2.html
