Hp/tq gain question.
Old 11-06-2013, 08:37 PM
philip77o
philip77o's Avatar
Default Hp/tq gain question.
Hi, I'd like to know what kind of rwhp/tq can I expect out of a 1986 951 with chips, dual port wastegate, 3bar fuel pressure reg and a 3" exhaust without cat ?
Thank you !
Old 11-06-2013, 09:06 PM
eman930
eman930's Avatar
Depends what PSI your running.. I have basically that setup at 17psi and zi think it's somewhere around 280hp
Old 11-06-2013, 09:17 PM
philip77o
philip77o's Avatar
280 whp or flywheel hp ? and you have k26/8 ?
Old 11-06-2013, 09:19 PM
Paulyy
Professional Hoon
Paulyy's Avatar
anywhere from 250 to 280 rwhp and from 250 to 300 rwtq. depends on how good your turbo is, your engine condition, wastegate, tune ect.
Old 11-06-2013, 09:21 PM
eman930
eman930's Avatar
That's Rwhp and yes that with a K26/8
Old 11-06-2013, 10:00 PM
Paulyy
Professional Hoon
Paulyy's Avatar
You wont run the k26/6 past 15 psi. Just dies off to 11-12 psi to quickly.
Old 11-06-2013, 11:11 PM
philip77o
philip77o's Avatar
Does it worth installing a turbo down pipe or it's a $400 to the trash ?
Old 11-06-2013, 11:14 PM
Paulyy
Professional Hoon
Paulyy's Avatar
IMO Useless as the ID of the stock down pipe is the same as the ID of the turbine housing outlet.
Old 11-07-2013, 06:28 AM
t3rra
t3rra's Avatar
MIT be worth giving this a go
http://www.augmentautomotive.co.uk/augtronic
I've got it on mine 26/8 running 1.3 bar and hold it to at 6k
I've got stage 2 intercooler Portland polished manifold and throttle body
80lb injectors
High flow fuel pump
Tial 38 Dpw
Apexi ebc
Map
Wide band
I've not dyno mine yet. A low speed roll start 10/100 in 10 secs
Tom made 330 hp on 26/6 at 1.1 bar but I think he only got 300 hp dyno sheet up.
Old 11-07-2013, 07:35 AM
Paulyy
Professional Hoon
Paulyy's Avatar
80lb injectors
High flow fuel pump
Tial 38 Dpw
Apexi ebc
Map
Wide band
how do you make 330 rwhp on a 26/6 when it doesn't even flow enough air to produce that power?
Old 11-07-2013, 07:41 AM
eman930
eman930's Avatar
80lb injectors
High flow fuel pump
Tial 38 Dpw
Apexi ebc
Map
Wide band
This web site is kinda awesome... How have I not heard of this ECU before... It's like Rouge Tuning on steroids
Old 11-07-2013, 08:20 AM
Van
Van's Avatar
Personally, I think you guys are very optimistic... I've dyno'ed several turbos, and found that a stock car will make about 200 WHP. You can see on this chart that it took quite a lot of extra boost to make 250 whp (and that's a good running car (technoduck)).
FWIW, I've had nearly a dozen 951s on my dyno - all with different mods - and none have broken 300 WHP.
To the OP, I'd say you're at 200 WHP now, and with a chip - and your other stuff - you'll get up to 220 WHP.
Old 11-07-2013, 08:26 AM
eman930
eman930's Avatar
Can you list the mods done?
Old 11-07-2013, 08:47 AM
Van
Van's Avatar
These were from 2010...
The green, technoduck's car, had quite a bit - certainly exhaust, chips, and so-on. I think he had a different turbo, too. I don't recall if he had the AFM or a MAF, thought.
The red was a 100% stock car.
And the blue was my turbo, which had chips, LBE and 3" straight pipe exhaust.
Old 11-07-2013, 09:28 AM
Paulyy
Professional Hoon
Paulyy's Avatar
Just to note. When i had my k26/6. I had the following:
MBC
TiAL 38mm
Factory euro (no cat) exhaust
Huntley Racing chips
AFMLink piggy back (0 restriction to the turbo)
FMIC
I would get 15 psi @ 2800 rpm. My car would walk on a factory VZ Monaro from a roll at 80 km/h Even modified ones with cams ect. Just to put it in perspective how powerful my 952 was with the stock turbo.
Quick Reply: Hp/tq gain question.
