High Z injectors
![Arrow](https://rennlist.com/forums/images/icons/icon2.gif)
Opinions on the new High Z technology ? Reason I ask , one of my 95lb Delphi injectors is locking up, so i am in the market
![](http://forums.rennlist.com/upload/fic_spec_sheet_001_582x800.jpg)
![](http://forums.rennlist.com/upload/img_20130905_195714_781_800x450.jpg)
I´m also wondering.
I´ve heard lots of positive about the new bosch motorsport 1000-1700cc injectors.
(who people sell under their own brand i think?)
For example FIC and injector dynamics
The 944 uses peak and hold injectors as i understand and this is saturated.
But rogue tuning offers 80lbs high Z saturated injectors to his maf.
is it possible to run saturated on original dme?
Small Business Partner
Yes, high-Z injectors can be run with the DME - with correct software changes.
Generally you can use high-Z injectors with peak & hold drivers, but not the other-way-around.
The waveform above looks right but the DC levels are not. Using your piggy back and fuel pressure, you should be able to dial them in.
Since your already running 1200cc injectors I think you have already made most of the software changes needed ?? I pulled resistors and dialed in fuel ratio by piggyback, doing an autocross tomorrow, we will see how it goes.
even if they are at the same 1200cc flow
I think i also need to have some changes to the software because the old injectors are peak and hold and the new is saturated?
As a generality, saturated injectors are slower to respond than peak&hold.
This is why I mentioned a software change earlier. You will need to update the injector latency settings for the slower injectors, and need to be running in a 1 inj/720° batch-fire mode).
You can possibly tune around it with a piggyback - as long as the latter is true.
